15 years agoHelp with statemachine/verilog
Hello to everyone, i am having a lot of trouble to work with state machines using verilog! here is my code
module maquina_irig
clk_mi,
rstn_mi,
zero_mi,
15 years ago --- Quote Start --- You apparently intend to send them sequentially. Using two states is the siimplest way.. --- Quote End --- Yes i've done that, but now my state machine has 20 states, where 10 of them is just a replicated state F.E
SECOND:
begin
if(ts_mi==0)
sinal_mi <= zero_mi;
else if(ts_mi==1)
sinal_mi <= um_mi;
end
P_BEFORE_MINUTE:
begin
sinal_mi <= p_mi;
end
I need to verify the bits on a byte reponsable for the seconds, then send a "p_mi" signal, and it goes like this untill years! seconds->p_mi->minuts->p_mi->hours-> ....... ->years All the p_before (minute/hour..etc) has the same code Same applies for the hour/minut etc.. .. Is there some way to do a simplification? Thanks for the support
