15 years agoHelp with statemachine/verilog
Hello to everyone, i am having a lot of trouble to work with state machines using verilog! here is my code
module maquina_irig
clk_mi,
rstn_mi,
zero_mi,
15 years ago --- Quote Start --- Quartus II has a template menu option with some state machine implementations that you can look at. With a verilog or VHDL file open got to Edit --> Insert Template and choose the one you want to use. --- Quote End --- Thanks for the tip. I am using the Moore state machine now. My output is a 1bit reg. I want to send in one state two signals, "1" and "0" in the same state How can i do that? I can't just do Initial_State: begin out<= 1; out<= 0; end right? Thanks..
