15 years agoHelp with statemachine/verilog
Hello to everyone, i am having a lot of trouble to work with state machines using verilog! here is my code
module maquina_irig
clk_mi,
rstn_mi,
zero_mi,
15 years agoThe error is caused by simple violation of Verilog syntax. You can't drive the variable next_state in more than one place.
But it's completely unclear, why you did it all. Apparently you have copied second always block without thinking. The assignment next_state = current_state; in the third always block is simply useless. In addition, assigning both next_state and current_state in an edge sensitive always block is far from a reasonable FSM design. It causes an unwanted delay of one clock cycle and possibly strange behaviour. I suggest to use FSM examples from a Verilog text book as astarting point.
