15 years ago
Handling large amount of Data between modules in Verilog
Hi all,
I want to handle large amounts of data between Modules.
I somehow need to connect up to 1024 inputs and 1024 outputs which are [16:0] width each. For the moment, the only solution which came to my mind is the following:
input       inp_fre_0;
input       inp_fre_1023;
output       out_fre_0;
output       out_fre_1023;
However, it appears to me that this is not the ideal solution and somehow bad style.
For registers, Verilog offers packed array registers
reg      rex_fim_X1;
Is there anything similar for Inputs and Outputs? Quartus says that there is something similar available in SystemVerilog. However i don't wanna start with this since I'm still having enough trouble with Verilog itself...
Is there maybe an even better way to do the data handling besides using inputs and outputs?
A little inspiration (and a short code sample :)) would really be appreciated.
Cheers,
Jonas
    I essentially tried what nplttr shows before I posted my second reply.
    Looks like I'll stick to VHDL, it may be a bit verbose sometimes, but at least I don't have to paste/copy/edit two sets of 1024 lines to declare what jonas.lindmann wants. In VHDL it is as simple (at first sight) as :
     port (
    inp_fre : in std_logic_2D(1023 downto 0 , 16 downto 0) ;
    or with parameters :
    entity ttt is
      generic (
         NUM_OF_PORTS : natural := 1024 ;
         WIDTH_PORT  : natural := 17
       port (
         inp_fre : in std_logic_2D(NUM_OF_PORTS - 1 downto 0 , WIDTH_PORT - 1 downto 0) ;
    end ttt ;
    It seems there is no Verilog equivalent for this? Great :eek:
    I wonder why Altera switched from AHDL to Verilog for their building blocks? It looked like they were going to switch to VHDL, which partly convinced me of VHDL too.
    I tried josyb solution but wasn't able to let it work.
    How to index the internal signals that now have a double index?
    If I declare it like this:
    --- Quote Start ---
    module tmp2(A[1:0],Y);
    input [7:0]A;
    wire [7:0] A;
    output [7:0] Y;
    wire [7:0] Y;
    assign Y = A+{A,1'b1};
    endmodule
    --- Quote End ---
    it looks like A is a 2bit signal
    --- Quote Start ---
    module tmp2(A[7:0],Y);
    input [1:0]A;
    wire [1:0] A;
    output [7:0] Y;
    wire [7:0] Y;
    endmodule
    --- Quote End ---
    I get an error
    Any hint?
    Alas, I tried it in Quartus II after reading FvM's post and it doesn't work. Looks like Verilog is quite limited , so stepping up to SystemVerilog seems to be the advice ... so I'll have to look for a good book on SystemVerilog
    System Verilog brings also structurized data types (e.g. arrays) for module interfaces, but standard Verilog hasn't it. So you have to represent the connection by a large [17*1024-1..0] "flattened" vector. But that's no problem for the design compiler, bad readability is probably the main drawback.
    You'lll need a rather large FPGA to have about 17500 internal signals, and also a considerable amount of routing resources. Did you verify, that the design is feasible, apart from the particular module connection problem?
    I'm not a Verilog expert (not even close as I use VHDL for about five years now, after using AHDL for over 10 years) but I checked Thomas & Moorby's 'The Verilog Hardware Description Language' and looking into a MegaWizard generated .v file, I feel it should work like this
    module ttt (
    	inp_fre  ,
    	input	  inp_fre;
    endmodule
