15 years agoHandling large amount of Data between modules in Verilog
Hi all, I want to handle large amounts of data between Modules. I somehow need to connect up to 1024 inputs and 1024 outputs which are [16:0] width each. For the moment, the only solution ...
15 years agoI essentially tried what nplttr shows before I posted my second reply.
Looks like I'll stick to VHDL, it may be a bit verbose sometimes, but at least I don't have to paste/copy/edit two sets of 1024 lines to declare what jonas.lindmann wants. In VHDL it is as simple (at first sight) as : port (
inp_fre : in std_logic_2D(1023 downto 0 , 16 downto 0) ;
) ; or with parameters : entity ttt is
generic (
NUM_OF_PORTS : natural := 1024 ;
WIDTH_PORT : natural := 17
port (
inp_fre : in std_logic_2D(NUM_OF_PORTS - 1 downto 0 , WIDTH_PORT - 1 downto 0) ;
end ttt ;
It seems there is no Verilog equivalent for this? Great :eek: I wonder why Altera switched from AHDL to Verilog for their building blocks? It looked like they were going to switch to VHDL, which partly convinced me of VHDL too.
