15 years agoHandling large amount of Data between modules in Verilog
Hi all, I want to handle large amounts of data between Modules. I somehow need to connect up to 1024 inputs and 1024 outputs which are [16:0] width each. For the moment, the only solution ...
15 years agoI tried josyb solution but wasn't able to let it work.
How to index the internal signals that now have a double index? If I declare it like this: --- Quote Start --- module tmp2(A[1:0],Y); input [7:0]A; wire [7:0] A; output [7:0] Y; wire [7:0] Y; assign Y = A+{A,1'b1}; endmodule --- Quote End --- it looks like A is a 2bit signal If I declare it like this: --- Quote Start --- module tmp2(A[7:0],Y); input [1:0]A; wire [1:0] A; output [7:0] Y; wire [7:0] Y; assign Y = A+{A,1'b1}; endmodule --- Quote End --- I get an error Any hint?
