15 years ago
Floading Point divider, throughput/latency
Hi all,
I'm considering using the floading point blocks available from Altera in a design I have. Throughput is a top priority as I'm doing complex image transformation for high speed application.
I was trying out the altfp_div megafunction and found out that it outputs only correct answers every other clock cycle, possibly worse as I only tried it with two numbers. Is the altfp_div not fully pipelined? I saw this also with latency set to 14.
I have added figures with this where div6rest_result is the correct values and div6_result_real is the value form the altfp_div.
I also did the same for the altfp_inv floating point inverter. It seems to output correct values when receiving data every cycle.
I also added a zip file with this test made in Quartus 9.1
Cheers
Stefan
p.s. Second question I have is are those megafunctions free to use with the web edition?
