15 years agoFloading Point divider, throughput/latency
Hi all, I'm considering using the floading point blocks available from Altera in a design I have. Throughput is a top priority as I'm doing complex image transformation for high speed application...
15 years ago --- Quote Start --- How do you suggest doing this in synthesizableRTL code? --- Quote End --- I do not suggest to do this in synthesizable RTL Code. I suggest to do this in testbench. Testbenches are not for synthesys and it is your decision when to let the input data change.
