15 years ago
error in dual edge dff in vhdl
Some where in web I found a dual edge DFF in vhdl and add to my cyclone iii project, after compiling there comes a strange error message :
Error (10327): VHDL error at fdff.vhd(20): can't determine definition of operator ""="" -- found 0 possible definitions
and my codes are :
library IEEE ;
use IEEE.STD_LOGIC_1164.ALL,IEEE.Numeric_std.ALL;
entity edff is
generic (
impl_rn : integer := 1 ;
impl_sn : integer := 1 ) ;
port (
rn : in std_ulogic ;
sn : in std_ulogic ;
d : in std_ulogic ;
c : in std_ulogic ;
q : out std_ulogic ) ;
end edff ;
architecture behavior of edff is
signal ff_rise , ff_fall : std_ulogic ;
begin
process ( rn , sn , c )
begin
if ( impl_rn = 1 and rn = 0 ) then
ff_rise <= 0;
elsif ( impl_sn = 1 and sn = 0 ) then
ff_rise <= 1;
elsif rising_edge ( c ) then
if ( d = 1 ) then
ff_rise <= not( ff_fall ) ;
else ff_rise <= ff_fall ;
end if ;
end if ;
end process ;
begin
if ( implrn =1 AND rn = 0 ) then
ff_fall <= 0;
elsif ( implsn =1 AND sn = 0 ) then
ff_fall <= 0;
elsif falling_edge ( c ) then
if ( d = 1 ) then
ff_fall <= not( ff_rise ) ;
else ff_fall <= ff_rise ;
end if ;
end if ;
end process ;
q <= 0 when ( implrn =1 AND rn = 0 ) else
1 when ( impl_sn =1 AND sn = 0 ) else
ff_ris XOR ff_fall ;
end behavior ;
Can someones help me solve this problem ???
    Altera FPGA have double data rate (DDR) in- and output registers to read or write data signals valid on both edges. No need to use dubious dual-edge clocked FFs.
    Thanks all of your replies , I upload part of my quartus design file which is used for 8 inputs channels from two AD9481 in interleaving mode ( used for DSO ) . Two PLL generates two 100M , max 125M clock ( 180 phase difference from each other ) feed to two CLK_MODULE , which is a clock divider , from the value of SEL [4:0] , so 1Hz to 100M Hz is generated out of MEM_CLK_OUT and 2.5MHz to 125MHz is generated out of ADC_CLK_OUT ( to AD9481) . Both of MEM_CLK_OUT are input to one clk input of module MEM_CONTROL_H , for some reasons only one input can be used as I cannot find way to modify it . The function of CLK input of MEM_CONTROL_H is on every raising edge of input CLK , ADC_CH1_DATA[ 7:0] and ADC_CH2_DATA [7:0] is put into two array of size 8192 . The problem is how can I combine two 180 phase difference clock to one input clock to MEM_CONTROL_H ????
    When you fix the various typos and missing quotes for binary constants, the design can compile in Quartus. I suggest, that you'll try it and find out yourself, which problems are involved with it.
    As an additional issue, newer FPGA families don't have asynchronous set for FFs. So Quartus must implement additional latches to emulate the set/reset function for ff_rise. You should decide, if it's actually needed for your design.
    why does the input clock vary? That is generally not a good idea for an FPGA. Best to have a system clock and then get the data from the input clock into the system clock domain.
    And I know 1Hz is not suitable for a PLL. I think there is a minimum of 1MHz or something.
    Please explain where this clock comes from. If it varies like you say, then its not really a clock.
    for Megafunction using PLL , i have to enter the input clock value , but my input clock is vary from 1Hz to 125MHz , is it possible input a "false" input value said 50M to PLL but the actual value is from 1Hz to 125MHz so that a 2Hz to 250 MHz output from PLL ??? Can I use other method rather than PLL ??
    FPGA will be fine, when you understand what you are doing. Would this clock vary or be constant? why cant you use a PLL just to multiply the clock by 2? that way you can use a toggle bit to detect the two different "edges".
    What are you actually trying to do?
    The input clock is from 1Hz to 125M Hz , without using FPGA I cannot find other suitable IC do the job !!
    first of all, dual edge flip flops are not suitable for FPGA designs. I recommend you just double the clock rate and do it that way instead.
    Secondly, you need to compare std_ulogics to '0' or '1', not 0 or 1. 0 is an integer, '0' is one of std_ulogic's enumerated types.
