18 years ago
Error: Can't synthesize current design -- Top partition does not contain any logic
Dear Sir,
I am trying one code for verilog traffic signal controller, but it seems the above error?
would you please tell me how to solve this??
the code is below:
module traffic;
parameter on = 1, off = 0, red_tics = 35,
amber_tics = 3, green_tics = 20;
reg clock, red, amber, green;
// will stop the simulation after 1000 time units
initial begin: stop_at
# 1000; $stop;
end
// initialize the lights and set up monitoring of registers
initial begin: Init
red = off; amber = off; green = off;
$display(" Time green amber red");
$monitor("%3d %b %b %b", $time, green, amber, red);
end
// task to wait for 'tics' positive edge clocks
// before turning light off
task light;
output color;
input [31:0] tics;
begin
repeat(tics) // wait to detect tics positive edges on clock
@(posedge clock);
color = off;
end
endtask
// waveform for clock period of 2 time units
always begin: clock_wave
# 1 clock = 0;
# 1 clock = 1;
end
always begin: main_process
red = on;
light(red, red_tics); // call task to wait
green = on;
light(green, green_tics);
amber = on;
light(amber, amber_tics);
end
endmodule
sincerely
Kazi Mamun
Yeungnam University
South Korea
    --- Quote Start ---
    Thanks Pletz,
    Atlast I did my required project with the code below, thanks a lot for your help.
    //Verilog HDL code for intelligent Traffic system with 7seg display properties:
    module traffic1(R, G, Y, pm, clock, reset,seg7);
    output R, Y, G; // Red, Yellow, Green Signal lines
    input clock, reset, pm;
    reg R, Y, G;
    output [6:0]seg7; // 7bit is output signal
    reg [6:0]seg7; // Define 7bit register
    //state machine parameters
    reg [1:0] present_state, next_state;
    parameter Green = 2'b00,
    Yellow = 2'b01,
    Red = 2'b10,
    Reset_State = 2'b11;
    // clock divider
    reg [27:0] divider;
    reg [24:0] divider1;
    reg reg1;
    reg temp;
    wire enable_state;
    // counter as clock divider
    always @(posedge clock) begin
    if (reset) divider <= 0 ;
    else divider <= divider + 1;
    if (reset) divider1 <= 0;
    else divider1 <= divider1 + 1;
    end
    if (reset) reg1 <= 0;
    else if (pm) reg1<= divider1[24];
    else reg1 <= divider[27];
    end
    // edge detector for counter bit [3]
    // Needed to make the enable signal one clock cycle long
    if (pm) temp <= divider1[24]& !reg1;
    else
    temp <= divider[27]& !reg1;
    end
    assign enable_state = temp;
    // End clock divider
    always @ (posedge clock)
    begin
    if(reset)
    present_state = Reset_State;
    else if (enable_state)
    present_state = next_state;
    end
    always @ (present_state)
    case (present_state)
    Green:
    begin
    G = 1'b1;
    R = 1'b0;
    //Y = 1'b0;
    next_state = Yellow;
    end
    Yellow:
    begin
    Y = 1'b1;
    G = 1'b0;
    //R = 1'b0;
    next_state = Red;
    end
    Red:
    begin
    R = 1'b1;
    Y = 1'b0;
    //G = 1'b0;
    next_state = Green;
    end
    Reset_State:
    begin
    R = 1'b0;
    Y = 1'b0;
    G = 1'b0;
    next_state = Red;
    end
    endcase
    always @(pm)
    begin
    case(pm) // flollw operation of a
    1'b1 : seg7 = 7'b0001000; //A
    default : seg7 = 7'b0001100; //P
    endcase
    end
    endmodule
    --- Quote End ---
    Hi thwijoo,
    congratulation to have your first(?) design running. Hopefully I could help you a little bit.
    Bye
    Thanks Pletz,
    reg R, Y, G;
    Yellow = 2'b01,
    Red = 2'b10,
    // clock divider
    reg [27:0] divider;
    reg reg1;
    reg temp;
    wire enable_state;
    end
    end
    else
    end
    begin
    if(reset)
    end
    Green:
    begin
    G = 1'b1;
    R = 1'b0;
    //Y = 1'b0;
    end
    Yellow:
    begin
    Y = 1'b1;
    G = 1'b0;
    //R = 1'b0;
    next_state = Red;
    end
    Red:
    begin
    R = 1'b1;
    Y = 1'b0;
    //G = 1'b0;
    next_state = Green;
    end
    Reset_State:
    begin
    R = 1'b0;
    Y = 1'b0;
    G = 1'b0;
    next_state = Red;
    end
    endcase
    always @(pm)
    begin
    endcase
    end
    endmodule
    --- Quote Start ---
    Dear Sir,
    Thanks for your reply.
    to see the changing effect on DE2 board, is that okey if I increase delay with# 1000??
    or what else, I can do if I want to see the change?
    sincerely
    Kazi Mamun
    --- Quote End ---
    Hi Kazi,
    unfortunately# <value> could not be used for synthesis. You have to slow down the state machine. I have added a clock divider to your design, in order to generate an enable puls for the state machine. In the example the state machine changes now only every 4th clock the state. If you need it slower you simply have to make the counter larger and chose always the MSB for the enable generator. Simulate the design and try to understand how it works.
    module traffic1(R, G, Y, clock, reset);
    input clock, reset;
    reg R, Y, G;
    Yellow = 2'b01,
    Red = 2'b10,
    // clock divider
    reg [3:0] divider;
    reg reg1;
    wire enable_state;
    if (reset) divider <= 0;
    end
    else reg1 <= divider[3];
    end
    assign enable_state = divider[3]& !reg1;
    begin
    if(reset)
    end
    Green:
    begin
    G = 1'b1;
    R = 1'b0;
    Y = 1'b0;
    end
    Yellow:
    begin
    Y = 1'b1;
    G = 1'b0;
    R = 1'b0;
    next_state = Red;
    end
    Red:
    begin
    R = 1'b1;
    Y = 1'b0;
    G = 1'b0;
    next_state = Green;
    end
    Reset_State:
    begin
    R = 1'b0;
    Y = 1'b0;
    G = 1'b0;
    next_state = Red;
    end
    endcase
    endmodule
    Dear Sir,
    sincerely
    Kazi Mamun
    --- Quote Start ---
    ]I am really thankful for your reply,
    I have tried with another code also, but problem with that code is the light changes if I turn of and turn on the switch.
    but my target is simple, just implement a system that contain three light, the light will change automatically after a certain time.
    would please check the code below??
    input clock, reset;
    reg R, Y, G;
    Yellow = 2'b01,
    Red = 2'b10,
    begin
    if(reset)
    else if (~reset)
    end
    Green:
    begin
    G = 1'b1;
    R = 1'b0;
    B = 1'b0;
    end
    Yellow:
    begin
    Y = 1'b1;
    G = 1'b0;
    R = 1'b0;
    next_state = Red;
    end
    Red:
    begin
    R = 1'b1;
    Y = 1'b0;
    G= 1'b0;
    next_state = Green;
    end
    Reset_State:
    begin
    R = 1'b0;
    Y = 1'b0;
    G = 1'b0;
    next_state = Red;
    end
    endcase
    endmodule
    with regards
    Kazi Mamun
    --- Quote End ---
    Hi Kazi,
    you forgot to define the value for some signals, which leads to infering latches. Be aware that your output changes every clock cycle. If you coonect the outputs to a LED and your clock speed is high, I 'm not sure that you can see any change.
    input clock, reset;
    reg R, Y, G;
    Yellow = 2'b01,
    Red = 2'b10,
    begin
    if(reset)
    else if (~reset)
    end
    Green:
    begin
    G = 1'b1;
    R = 1'b0;
    end
    Yellow:
    begin
    Y = 1'b1;
    G = 1'b0;
    next_state = Red;
    end
    Red:
    begin
    R = 1'b1;
    Y = 1'b0;
    next_state = Green;
    end
    Reset_State:
    begin
    R = 1'b0;
    Y = 1'b0;
    G = 1'b0;
    next_state = Red;
    end
    endcase
    endmodule
    with regards
    Kazi Mamun
    --- Quote Start ---
    Dear Sir,
    the code is below:
    module traffic;
    # 1000; $stop;
    end
    initial begin: Init
    end
    task light;
    output color;
    input [31:0] tics;
    begin
    @(posedge clock); color = off;
    end
    endtask
    # 1 clock = 0;
    # 1 clock = 1;
    end
    red = on;
    green = on;
    amber = on;
    end
    endmodule
    sincerely
    Kazi Mamun
    Yeungnam University
    South Korea
    --- Quote End ---
    Hi Kazi,
    it is not only that you don't have specified input and outputs in your top module. There are also a lot of parts ( I have mark some red) which could not be used for synthesis. What have written is more or less a behavioral description of your design. That is fine for simulation, but you have to change your code for synthesis. Maybe somebody in the forum could recommand a verilog tutorial or a good book to start with.
    Looks to me like your top level module does not contain any outputs, i.e. your logic does not drive any pins. The synthesiser will remove all logic that does not effect an output.
    Hope this helps
