18 years agoError: Can't synthesize current design -- Top partition does not contain any logic
Dear Sir, I am trying one code for verilog traffic signal controller, but it seems the above error? would you please tell me how to solve this?? the code is below: module traffic; param...
18 years ago --- Quote Start --- Dear Sir, Thanks for your reply. to see the changing effect on DE2 board, is that okey if I increase delay with# 1000?? or what else, I can do if I want to see the change? sincerely Kazi Mamun --- Quote End --- Hi Kazi, unfortunately# <value> could not be used for synthesis. You have to slow down the state machine. I have added a clock divider to your design, in order to generate an enable puls for the state machine. In the example the state machine changes now only every 4th clock the state. If you need it slower you simply have to make the counter larger and chose always the MSB for the enable generator. Simulate the design and try to understand how it works. module traffic1(R, G, Y, clock, reset); output R, Y, G; // Red, Yellow, Green Signal lines input clock, reset; reg R, Y, G; //state machine parameters reg [1:0] present_state, next_state; parameter Green = 2'b00, Yellow = 2'b01, Red = 2'b10, Reset_State = 2'b11; // clock divider // reg [3:0] divider; reg reg1; wire enable_state; // counter as clock divider always @(posedge clock) begin if (reset) divider <= 0; else divider <= divider + 1; end always @(posedge clock) begin if (reset) reg1 <= 0; else reg1 <= divider[3]; end // edge detector for counter bit [3] // Needed to make the enable signal one clock cycle long assign enable_state = divider[3]& !reg1; // End clock divider always @ (posedge clock) begin if(reset) present_state = Reset_State; else if (enable_state) present_state = next_state; end always @ (present_state) case (present_state) Green: begin G = 1'b1; R = 1'b0; Y = 1'b0; next_state = Yellow; end Yellow: begin Y = 1'b1; G = 1'b0; R = 1'b0; next_state = Red; end Red: begin R = 1'b1; Y = 1'b0; G = 1'b0; next_state = Green; end Reset_State: begin R = 1'b0; Y = 1'b0; G = 1'b0; next_state = Red; end endcase endmodule
