18 years agoError: Can't synthesize current design -- Top partition does not contain any logic
Dear Sir, I am trying one code for verilog traffic signal controller, but it seems the above error? would you please tell me how to solve this?? the code is below: module traffic; param...
18 years ago --- Quote Start --- Dear Sir, I am trying one code for verilog traffic signal controller, but it seems the above error? would you please tell me how to solve this?? the code is below: module traffic; parameter on = 1, off = 0, red_tics = 35, amber_tics = 3, green_tics = 20; reg clock, red, amber, green; // will stop the simulation after 1000 time units initial begin: stop_at # 1000; $stop; end // initialize the lights and set up monitoring of registers initial begin: Init red = off; amber = off; green = off; $display(" Time green amber red"); $monitor("%3d %b %b %b", $time, green, amber, red); end // task to wait for 'tics' positive edge clocks // before turning light off task light; output color; input [31:0] tics; begin repeat(tics) // wait to detect tics positive edges on clock @(posedge clock); color = off; end endtask // waveform for clock period of 2 time units always begin: clock_wave # 1 clock = 0; # 1 clock = 1; end always begin: main_process red = on; light(red, red_tics); // call task to wait green = on; light(green, green_tics); amber = on; light(amber, amber_tics); end endmodule sincerely Kazi Mamun Yeungnam University South Korea --- Quote End --- Hi Kazi, it is not only that you don't have specified input and outputs in your top module. There are also a lot of parts ( I have mark some red) which could not be used for synthesis. What have written is more or less a behavioral description of your design. That is fine for simulation, but you have to change your code for synthesis. Maybe somebody in the forum could recommand a verilog tutorial or a good book to start with.
