18 years agoError: Can't synthesize current design -- Top partition does not contain any logic
Dear Sir, I am trying one code for verilog traffic signal controller, but it seems the above error? would you please tell me how to solve this?? the code is below: module traffic; param...
17 years ago --- Quote Start --- Thanks Pletz, Atlast I did my required project with the code below, thanks a lot for your help. //Verilog HDL code for intelligent Traffic system with 7seg display properties: module traffic1(R, G, Y, pm, clock, reset,seg7); output R, Y, G; // Red, Yellow, Green Signal lines input clock, reset, pm; reg R, Y, G; output [6:0]seg7; // 7bit is output signal reg [6:0]seg7; // Define 7bit register //state machine parameters reg [1:0] present_state, next_state; parameter Green = 2'b00, Yellow = 2'b01, Red = 2'b10, Reset_State = 2'b11; // clock divider reg [27:0] divider; reg [24:0] divider1; reg reg1; reg temp; wire enable_state; // counter as clock divider always @(posedge clock) begin if (reset) divider <= 0 ; else divider <= divider + 1; if (reset) divider1 <= 0; else divider1 <= divider1 + 1; end always @(posedge clock) begin if (reset) reg1 <= 0; else if (pm) reg1<= divider1[24]; else reg1 <= divider[27]; end // edge detector for counter bit [3] // Needed to make the enable signal one clock cycle long always @(posedge clock) begin if (pm) temp <= divider1[24]& !reg1; else temp <= divider[27]& !reg1; end assign enable_state = temp; // End clock divider always @ (posedge clock) begin if(reset) present_state = Reset_State; else if (enable_state) present_state = next_state; end always @ (present_state) case (present_state) Green: begin G = 1'b1; R = 1'b0; //Y = 1'b0; next_state = Yellow; end Yellow: begin Y = 1'b1; G = 1'b0; //R = 1'b0; next_state = Red; end Red: begin R = 1'b1; Y = 1'b0; //G = 1'b0; next_state = Green; end Reset_State: begin R = 1'b0; Y = 1'b0; G = 1'b0; next_state = Red; end endcase always @(pm) begin case(pm) // flollw operation of a 1'b1 : seg7 = 7'b0001000; //A default : seg7 = 7'b0001100; //P endcase end endmodule --- Quote End --- Hi thwijoo, congratulation to have your first(?) design running. Hopefully I could help you a little bit. Bye
