18 years agoError: Can't synthesize current design -- Top partition does not contain any logic
Dear Sir, I am trying one code for verilog traffic signal controller, but it seems the above error? would you please tell me how to solve this?? the code is below: module traffic; param...
18 years ago --- Quote Start --- Hi, ]I am really thankful for your reply, I have tried with another code also, but problem with that code is the light changes if I turn of and turn on the switch. but my target is simple, just implement a system that contain three light, the light will change automatically after a certain time. would please check the code below?? module traffic1(R, G, Y, clock, reset); output R, Y, G; // Red, Yellow, Green Signal lines input clock, reset; reg R, Y, G; //state machine parameters reg [1:0] present_state, next_state; parameter Green = 2'b00, Yellow = 2'b01, Red = 2'b10, Reset_State = 2'b11; always @ (posedge clock) begin if(reset) present_state = Reset_State; else if (~reset) present_state = next_state; end always @ (present_state) case (present_state) Green: begin G = 1'b1; R = 1'b0; B = 1'b0; next_state = Yellow; end Yellow: begin Y = 1'b1; G = 1'b0; R = 1'b0; next_state = Red; end Red: begin R = 1'b1; Y = 1'b0; G= 1'b0; next_state = Green; end Reset_State: begin R = 1'b0; Y = 1'b0; G = 1'b0; next_state = Red; end endcase endmodule with regards Kazi Mamun --- Quote End --- Hi Kazi, you forgot to define the value for some signals, which leads to infering latches. Be aware that your output changes every clock cycle. If you coonect the outputs to a LED and your clock speed is high, I 'm not sure that you can see any change.
