wangduoyu
1 month agoDoes direct connection of two AXI4 Masters to DDR Slave support auto-arbitration on Agilex 5?
Hi all,
I'm developing on the Agilex 5 platform and need two AXI4 masters to access the DDR.
I noticed there isn't a standalone IP similar to Xilinx's axi_interconnect. Is it correct to simply connect two AXI masters directly to the single DDR AXI slave port (as shown below)? Will the interconnect fabric generate the necessary arbitration and routing logic in this case?
The issue has been resolved. The root cause was that parameters from the upstream module were not propagated correctly, which caused this specific Master path to be optimized away during synthesis. Thank you all for your suggestions
