wangduoyu
10 months agoDoes direct connection of two AXI4 Masters to DDR Slave support auto-arbitration on Agilex 5?
Hi all, I'm developing on the Agilex 5 platform and need two AXI4 masters to access the DDR. I noticed there isn't a standalone IP similar to Xilinx's axi_interconnect. Is it correct to simply conn...
- 10 months ago
The issue has been resolved. The root cause was that parameters from the upstream module were not propagated correctly, which caused this specific Master path to be optimized away during synthesis. Thank you all for your suggestions
AdzimZM_Altera
10 months agoHi wangduoyu,
What type of synthesis away warning you got?
Did you run the read and write test with AXI_master1?
Maybe you can add attribute "/* synthesis preserve */" to the register?
Adzim
wangduoyu
10 months agoThe issue has been resolved. The root cause was that parameters from the upstream module were not propagated correctly, which caused this specific Master path to be optimized away during synthesis. Thank you all for your suggestions
