wangduoyu's avatar
wangduoyu
10 months ago
Does direct connection of two AXI4 Masters to DDR Slave support auto-arbitration on Agilex 5?
Hi all, I'm developing on the Agilex 5 platform and need two AXI4 masters to access the DDR. I noticed there isn't a standalone IP similar to Xilinx's axi_interconnect. Is it correct to simply conn...
  • wangduoyu's avatar
    wangduoyu
    10 months ago
    The issue has been resolved. The root cause was that parameters from the upstream module were not propagated correctly, which caused this specific Master path to be optimized away during synthesis. Thank you all for your suggestions
