Does direct connection of two AXI4 Masters to DDR Slave support auto-arbitration on Agilex 5?
- 10 months ago
The issue has been resolved. The root cause was that parameters from the upstream module were not propagated correctly, which caused this specific Master path to be optimized away during synthesis. Thank you all for your suggestions
Yes, this is how it should work.
Be sure to check the addressing for both of those AXI managers on the Address Map tab to make sure the EMIF is at the address location you want, especially if it should be different for the two managers.
- wangduoyu10 months ago
Thanks. Is it necessary to use an AXI Bridge to solve the addressing issue? Currently, my custom defined AXI Master shows no options in the Address Map tab, even after I connect it to the DDR in the System View
- sstrell10 months ago
What are you seeing on the Address Map tab? You have to select the manager from the list on the left to see its address map. Every host/manager has its own address map.
As shown in the screenshot below, the address ranges for these two AXI Masters are automatically assigned based on the EMIF's "Die Density" parameter.
My current configuration is: Total DDR Density = 8Gb x 2 Channels = 16Gb (2GB).
Consequently, Platform Designer automatically maps both AXI Masters to the address range 0x0000_0000 - 0x7FFF_FFFF. If I attempt to manually modify this range, the system reports an "address out of range" error.
Could you please advise on how to handle this situation correctly?
