Devide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare.
When I try with "*" (multiply) or "+" (add), it is ok. I don't know this error, Please help me. Thank you very much.37 Replies
comment out std_logic_arith and std_logic_unsigned packages. Bring back numeric_std package.
Then make remainder and divider signals signed types. You cannot assign a "signed" type to a std_logic_vector. - Altera_Forum
I had finished my program. But I don't know how to make sign for the value less than 0. Can you help me?
This is my codelibrary IEEE; USE IEEE.std_logic_1164.all; USE IEEE.std_logic_arith.all; --USE IEEE.numeric_std.all; USE IEEE.std_logic_unsigned.all; Entity Devide is Port ( A,B : In std_logic_vector(7 downto 0); --A/B Quotients,Remainder_out : Out std_logic_vector(7 downto 0); CLK : In std_logic); end Devide; Architecture structural of Devide is Signal Remainder,Divider : std_logic_vector(7 downto 0);--:=dividend; Signal Result : std_logic_vector(7 downto 0); Signal CNT : std_logic_vector(3 downto 0); Begin Process(clk) Begin if clk='1' and clk'event then cnt<=cnt+1; if cnt="0000" then if B="00000000" then cnt<="0000"; else Remainder<= ABS (signed(A)); --Remainder = ABS(A) Divider<= ABS (signed(B)); -- Divider = ABS(B) end if; elsif cnt="0001" and Remainder >= Divider then Result<=Result+1; Remainder<=Remainder-Divider; elsif cnt="0010" and Remainder >= Divider then cnt<="0001"; elsif cnt="0011" then Quotients<=result; Remainder_out<=Remainder; elsif cnt="0100" then cnt<="0000"; result<="00000000"; end if; end if; end process; end structural; - Altera_Forum
--- Quote Start --- something like this... -- A_in/B_in = R (& rem remainder) -- R, rem initialised to zero -- A = abs(A_in), B = abs(B_in)
--- Quote End --- Thank Kaz very much. I try it now.clked process... rem <= A - B * R; if rem >= B then R <= R + 1; else result_out <= R; -- also decide sign here remainder_out <= rem; done <= '1'; end if; if B = 0 then alarm <= '1'; end if; - Altera_Forum
--- Quote Start --- The loop is infinite if 'Devider' is 0. No synthesizer will be able to synthesize this. It will also probably give strange results with a negative divider. While you are at it, you should use ieee.numeric_std and the signed and unsigned types rather than ieee.std_logic_signed. numeric_std is standard, makes it easier to mix signed and unsigned arithmetic, and makes the code more readable and maintainable. --- Quote End --- Ok. If the "Devider" is 0, the loop will infinite. Thank you for your advise. I will change to use numeric_std. --- Quote Start --- As tricky said even if you fixed this, it will result in massive parallel hardware, which probably isn't what you want. If you don't need the result in a single clock cycle, you should consider unrolling the operation over several cycles to get a much smaller hardware footprint. --- Quote End --- I want this process must finish before go to next step therefore i use loop. Do you have any idea for this process? - Altera_Forum
-- A_in/B_in = R (& rem remainder) -- R, rem initialised to zero -- A = abs(A_in), B = abs(B_in)clked process... rem <= A - B * R; if rem >= B then R <= R + 1; else result_out <= R; -- also decide sign here remainder_out <= rem; done <= '1'; end if; if B = 0 then alarm <= '1'; end if; - Altera_Forum
--- Quote Start --- You should not use loops to calculate values. Loops unroll into parrallel hardware. For loops do this quite nicely. While loops are more complicated and do not really map into hardware very well. Avoid using while loops in synthesisable code at all costs. --- Quote End --- Thank you very much. I'm very venous, I try a lot of method but now i still can not finish my project. I must try to make divide comment by code. If i don't use while or for loop, i can not have the result of divide comment. Do you have any suggest for this? - Altera_Forum
And I didn't see it at first, but as the process is using signals and not variables, the Remainder and Result signals can be considered as fixed during the process execution, and only updated once you get out of the process. So in fact I think that the loop is infinite in any case.
While you are at it, you should use ieee.numeric_std and the signed and unsigned types rather than ieee.std_logic_signed. numeric_std is standard, makes it easier to mix signed and unsigned arithmetic, and makes the code more readable and maintainable. As tricky said even if you fixed this, it will result in massive parallel hardware, which probably isn't what you want. If you don't need the result in a single clock cycle, you should consider unrolling the operation over several cycles to get a much smaller hardware footprint. - Altera_Forum
For loops do this quite nicely. While loops are more complicated and do not really map into hardware very well. Avoid using while loops in synthesisable code at all costs. - Altera_Forum
Dear my friend
I use While loop to implement divide algorithm in VHDL. But I met an error. Could you help me to solve this problem. Thank you very much. This is my code:
and this is error: --- Quote Start --- Error (10536): VHDL Loop Statement error at Divide.vhd(17): loop must terminate within 10,000 iterations Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings Info: Allocated 324 megabytes of memory during processing Error: Processing ended: Fri Dec 10 18:47:32 2010 Error: Elapsed time: 00:00:09 Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings --- Quote End --- In my opinion, this loop did not pass over 10.000 but it still error.library IEEE; USE IEEE.std_logic_1164.all; USE IEEE.std_logic_arith.all; USE IEEE.std_logic_signed.all; Entity Devide_Modelsim is Port ( Devidend,Devider : In std_logic_vector(7 downto 0); Quotients : Out std_logic_vector(7 downto 0)); end Devide_Modelsim; Architecture structural of Devide_Modelsim is Signal Remainder : std_logic_vector(7 downto 0):=devidend; Signal Result : std_logic_vector(7 downto 0); Begin Process(Remainder,Devider,result) Begin While (Remainder > Devider) loop Result<=Result+"1"; Remainder<=Remainder-Devider; End loop; Quotients<=result; end process; end structural;
