15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years ago --- Quote Start --- You should not use loops to calculate values. Loops unroll into parrallel hardware. For loops do this quite nicely. While loops are more complicated and do not really map into hardware very well. Avoid using while loops in synthesisable code at all costs. --- Quote End --- Thank you very much. I'm very venous, I try a lot of method but now i still can not finish my project. I must try to make divide comment by code. If i don't use while or for loop, i can not have the result of divide comment. Do you have any suggest for this?
