15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years agoI had finished my program. But I don't know how to make sign for the value less than 0. Can you help me?
This is my code
library IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_arith.all;
--USE IEEE.numeric_std.all;
USE IEEE.std_logic_unsigned.all;
Entity Devide is
Port (
A,B : In std_logic_vector(7 downto 0); --A/B
Quotients,Remainder_out : Out std_logic_vector(7 downto 0);
CLK : In std_logic);
end Devide;
Architecture structural of Devide is
Signal Remainder,Divider : std_logic_vector(7 downto 0);--:=dividend;
Signal Result : std_logic_vector(7 downto 0);
Signal CNT : std_logic_vector(3 downto 0);
Begin
Process(clk)
Begin
if clk='1' and clk'event then
cnt<=cnt+1;
if cnt="0000" then
if B="00000000" then
cnt<="0000";
else
Remainder<= ABS (signed(A)); --Remainder = ABS(A)
Divider<= ABS (signed(B)); -- Divider = ABS(B)
end if;
elsif cnt="0001" and Remainder >= Divider then
Result<=Result+1;
Remainder<=Remainder-Divider;
elsif cnt="0010" and Remainder >= Divider then
cnt<="0001";
elsif cnt="0011" then
Quotients<=result;
Remainder_out<=Remainder;
elsif cnt="0100" then
cnt<="0000";
result<="00000000";
end if;
end if;
end process;
end structural;
