15 years agoDevide in VHLD
I want to implement this function : A<= B/x"A", when I compile, the Quartus put a notice: "/" used but didn't declare. When I try with "*" (multiply) or "+" (add), it is ok. I don't know this er...
15 years agoDear my friend
I use While loop to implement divide algorithm in VHDL. But I met an error. Could you help me to solve this problem. Thank you very much. This is my code:
library IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_arith.all;
USE IEEE.std_logic_signed.all;
Entity Devide_Modelsim is
Port (
Devidend,Devider : In std_logic_vector(7 downto 0);
Quotients : Out std_logic_vector(7 downto 0));
end Devide_Modelsim;
Architecture structural of Devide_Modelsim is
Signal Remainder : std_logic_vector(7 downto 0):=devidend;
Signal Result : std_logic_vector(7 downto 0);
Begin
Process(Remainder,Devider,result)
Begin
While (Remainder > Devider) loop
Result<=Result+"1";
Remainder<=Remainder-Devider;
End loop;
Quotients<=result;
end process;
end structural;
and this is error: --- Quote Start --- Error (10536): VHDL Loop Statement error at Divide.vhd(17): loop must terminate within 10,000 iterations Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 0 warnings Info: Allocated 324 megabytes of memory during processing Error: Processing ended: Fri Dec 10 18:47:32 2010 Error: Elapsed time: 00:00:09 Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings --- Quote End --- In my opinion, this loop did not pass over 10.000 but it still error.
