DE1 Cyclone V Verilog
I create a small project using Quartus and Platform Designer.
In Platform Designer, I create NIOS II, On-Chip memory, JTAG UART and FIFO Avalon memory, I intrconnect them then I have generated Verilog , please see image below.
When I try to compile over Quartus, I get this error : Error (12002): Port "avalonmm_read_slave_read" does not exist in macrofunction "nios2_memory" , I know that it means that there is no signal in this name.
My question is, where are located the generated port signals ( Read from memory, write to memory) from generated by Platfom Designer, I found just clock signal and reset signal.
Please find attached the generated files by Platform Designer.
Thank you
- RichardT_altera
I have fixed the link.
Richard Tan
- RichardT_altera
I believe your follow-up question is related to Nios II, which unfortunately is not within my area of expertise.
Could you please raise a separate case for your follow-up technical problem, and an agent will be assigned to your case?
At Altera, we prefer a new case for each unique technical problem, as it aids our case analysis and helps us assess our customer support requirements.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
- Yassine-Ca
The link is not working.
Regards.
- RichardT_altera
I believe sstrell has answered your inquiry.
Do you need further help regarding this case?
Richard Tan
- Yassine-Ca
Hi Richard,
Thank you for your support.
I'm using Quartus 23.1, I have issue with Eclipse for NIOS II with elf file not existing.
I browse the Nios II Handbook, I found that the latest version of Quartus is 21.3
Can I get a problem of incompatibility.
Regards.
- Yassine-Ca
In the NIOS II new book, there is compatibility.
The problem was in the template in Eclipse, when I changed it to Helloworld small, the ELF file is generated.
I got these warnings on the Quartus:
Warning (10036): Verilog HDL or VHDL warning at seven_segment_display.v(18): object "display_data" assigned a value but never read
Info (12128): Elaborating entity "seven_segment_decoder" for hierarchy "seven_segment_decoder:temp_tens_decoder"
Warning (10036):............................To share the solution with you: I just added the module that declare the system components (NIOS 2+On Chip Memory + FIFO + JTAG) in the top level module declaration with the qip file added to the project.
Here the declaration inside top level,according to my project :
temp_hum u_rdwr (
.clk_clk(clk),
);Regards.
Yassine
- sstrell
For Nios II in older versions of Quartus, you have to use the bsp-editor from the Nios command shell to configure and generate the BSP.
- Yassine-Ca
Have you the link to download the version?.
Regards.
- Yassine-Ca
I installed eclipse, now it's OK.
I will procced to BSP files.
Regards.
- sstrell
Huh? No, that document has nothing to do with this. See this training: https://learning.intel.com/Developer/learn/courses/14714/niosr-v-software-development-flow-with-ashling-riscfree-ide-for-intelr-fpga
- Yassine-Ca
Sorry It was a mistake sending that reply in this page.
From Quartus I try to open NIOS 2 software build tool to generate BSP but no way.
What do you suggest, is the quartus version standard is not working for this?.
Best regards.
- sstrell
The _inst.v file is just an instantiation template for instantiated the PD system in an upper-level design file in Quartus. It only lists the exported interfaces, which in your case are just clock and reset.
If you are using this system as your top-level design in your Quartus project, set the top-level entity name in Quartus to NIOS2_memory_JTAG and add the .qsys file to your project. Regenerate the system in PD and then recompile in Quartus.
- Yassine-Ca
Thank you for your reply.
I use another file as my top-level, and i declare the NIOS2_memory_JTAG inside it.
Because I have the addresses of FIFO in, out and csr, on chip , nios2 debug memory slave, Can I just use these with bus address to write data to the FIFO memory.
Regards.
- sstrell
You mean in your code for the processor? Sure. But you can find all the macros in the generated system.h file from PD.
Side note: I don't know what version of Quartus you are using, but it's not recommended to start new designs with Nios II since it's been obsoleted by Nios V.
