DE1 Cyclone V Verilog
The _inst.v file is just an instantiation template for instantiated the PD system in an upper-level design file in Quartus. It only lists the exported interfaces, which in your case are just clock and reset.
If you are using this system as your top-level design in your Quartus project, set the top-level entity name in Quartus to NIOS2_memory_JTAG and add the .qsys file to your project. Regenerate the system in PD and then recompile in Quartus.
- Yassine-Ca1 year ago
Thank you for your reply.
I use another file as my top-level, and i declare the NIOS2_memory_JTAG inside it.
Because I have the addresses of FIFO in, out and csr, on chip , nios2 debug memory slave, Can I just use these with bus address to write data to the FIFO memory.
Regards.
- sstrell1 year ago
You mean in your code for the processor? Sure. But you can find all the macros in the generated system.h file from PD.
Side note: I don't know what version of Quartus you are using, but it's not recommended to start new designs with Nios II since it's been obsoleted by Nios V.
My FPGA is DE1 and the quartus prime version 23.1 std.
My top-level file is used to display retreived data from FIFO memory into 7-segments.
I serached for the system.h file but not found in project folders, where can I find it, as i mentioned the NIOS2 files was generated by Platform Designer Qsys.
Is the DE1 supports Nios V, if Yes I can start a new design.
Regards.
