DDR2 Read Issue in Cyclone III
I've instantiated a DDR2 SDRAM HPC using a Cyclone III. We've simulated the design and it works as expected. Using the hardware and SignalTap, I can do a write, and see the data on the mem_dq lines. When I do a read, I see the data come back on the mem_dq lines but the data is never on the local_rdata(255:0) bus. I believe the Quartus II version is 9.1. We are also using the half-data rate version. The DDR2 SDRAM is a PC-5300, 4GB Micron SO-DIMM. I'm thinking that I have a DDR2 controller issue. We are passing calibration because the ctl_cal_sucess line is high and local_init_done goes high after that.
Any thoughts? Any one else seeing this? Thanks!8 Replies
I forgot to write something,
I get an error after a while that stops the simulation. This is the error: # ** Failure: --- Data could not be written, increase array depth or use full memory model --- I have tried to change the memory_model to the full_memory_model but is not working. Is not even compiling. Regards, Juan - Altera_Forum
Dear Daixiwen,
Thanks for your reply. I have tried both. 1. I added by hand all the necessary files (from the memory controller ip core) and made sure that no other driver was interfering. 2. About the reading addresses. I am simply incrementing the address by 2. The address has this format: BANK-ROW-COL I would like to ask you for a further explanation of the address initialization. Maybe I still don't have this clear. In the Modelsim console I only get warning messages. Regards, Juan - Altera_Forum
I can think of two possibilities for those 'X':[list][*]you have a second driver in your testbench that forces a different value for local_rdata[*]you are reading an address that hasn't been initialized[/list]Do you have any error message or warning in the Modelsim console?
Hello again,
I just wanted to add the simulation error. Maybe if someone else has had this problem can give me a hand. Find attached the simulation wave.https://www.alteraforum.com/forum/attachment.php?attachmentid=6692 Regards, Juan - Altera_Forum
Hallo,
I am writing again to update my last comment. What I wrote previously is valid for: <variation name>_example_top_tb.vhd <variation name>_mem_model.vhd However, I was trying use my own test bench just using the memory model. Then It did not work. Apparently the solution to this is to modify the _example_top_tb.vhd and integrate it with your design. Or read carefully this testbench and add all the memory parameters for the functional simulation. Right now I am testing and at least there is result from the local_rdata bus in simulation. However, it is not stable. After few microseconds it is now showing any result. I am a bit confused with this simulation. However there must be a solution. Regards, Juan - Altera_Forum
Hello dtschindel,
...about the simulation and the local_rdata bus. In my case I didn't see any data because I was forgetting to use the memory model in the Quartus II settings. After I added the simulation model together with the test_bench file, I could see the local_rdata working. Maybe is interesting for you. Regards, Juan - Altera_Forum
Juan,
We could never get the Altera DDR2 Controller to work. We ended up writing our own DDR2 Controller for the Cyclone III. - Altera_Forum
Hello dtschindel,
I would like to ask you if you could solve this problem. If yes, How did you solve it? I am having the same situation. local_rdata = zero Thanks in advance, Juan
