15 years agoDDR2 Read Issue in Cyclone III
I've instantiated a DDR2 SDRAM HPC using a Cyclone III. We've simulated the design and it works as expected. Using the hardware and SignalTap, I can do a write, and see the data on the mem_dq lines...
13 years agoHello dtschindel,
...about the simulation and the local_rdata bus. In my case I didn't see any data because I was forgetting to use the memory model in the Quartus II settings. After I added the simulation model together with the test_bench file, I could see the local_rdata working. Maybe is interesting for you. Regards, Juan
