15 years agoDDR2 Read Issue in Cyclone III
I've instantiated a DDR2 SDRAM HPC using a Cyclone III. We've simulated the design and it works as expected. Using the hardware and SignalTap, I can do a write, and see the data on the mem_dq lines...
13 years agoI forgot to write something,
I get an error after a while that stops the simulation. This is the error: # ** Failure: --- Data could not be written, increase array depth or use full memory model --- I have tried to change the memory_model to the full_memory_model but is not working. Is not even compiling. Regards, Juan
