15 years agoDDR2 Read Issue in Cyclone III
I've instantiated a DDR2 SDRAM HPC using a Cyclone III. We've simulated the design and it works as expected. Using the hardware and SignalTap, I can do a write, and see the data on the mem_dq lines...
13 years agoHallo,
I am writing again to update my last comment. What I wrote previously is valid for: <variation name>_example_top_tb.vhd <variation name>_mem_model.vhd However, I was trying use my own test bench just using the memory model. Then It did not work. Apparently the solution to this is to modify the _example_top_tb.vhd and integrate it with your design. Or read carefully this testbench and add all the memory parameters for the functional simulation. Right now I am testing and at least there is result from the local_rdata bus in simulation. However, it is not stable. After few microseconds it is now showing any result. I am a bit confused with this simulation. However there must be a solution. Regards, Juan
