15 years agoDDR2 Read Issue in Cyclone III
I've instantiated a DDR2 SDRAM HPC using a Cyclone III. We've simulated the design and it works as expected. Using the hardware and SignalTap, I can do a write, and see the data on the mem_dq lines...
13 years agoDear Daixiwen,
Thanks for your reply. I have tried both. 1. I added by hand all the necessary files (from the memory controller ip core) and made sure that no other driver was interfering. 2. About the reading addresses. I am simply incrementing the address by 2. The address has this format: BANK-ROW-COL I would like to ask you for a further explanation of the address initialization. Maybe I still don't have this clear. In the Modelsim console I only get warning messages. Regards, Juan
