Cyclone10GX Temperature Issue
I use a cyclone 10 gx fpga (10CX150YF780C5G) on my pcie card. One transceiver is used as a 10Gbps fiber link and other 4 transceivers are used as Gen1 Pcie X4 lanes. No external memory interface. The total power consumption is about 2W.
The problem is when fpga's die temperature rises above about 55C, the transceiver that is used to connect the fiber link(SFP) has occurred missing word error in transmitting side. I use the transceiver loopback function to monitor the data both at a remote receiver output and at the local loopback receiver output. They show exactly same fault. It tells us the PCS stage in the transmitter side has something wrong. The reference clock to the transceiver ATX-pll is 644.53125MHz. Other functions in the fpga is working well.
When I lower the temperature by add a fan to blow it, it works normally. Is there any one knowing how to fix it?
Thanks a lot!
