YYang79
5 years agoCyclone10GX Temperature Issue
I use a cyclone 10 gx fpga (10CX150YF780C5G) on my pcie card. One transceiver is used as a 10Gbps fiber link and other 4 transceivers are used as Gen1 Pcie X4 lanes. No external memory interfa...
SengKok_L_Intel
5 years agoPlease refer to the following link (table 1), and check the GXB power supply (e.g. Vcct_GXB, Vccr_GXB, and Vcch_GXB), and determine if there is any difference between a pass and fail case. The FPGA is supposed to work at above 55C, and since you encounter it on multiple boards, so it is suspicious if there is a board issue.
Besides, you can send me a private message with the simple design, so that I can have a sanity check on it. Thanks.
YYang79
5 years agoI have checked the GXB powers. They are all within the range on table1, and unchanged with the temperature variation.
