Cyclone10GX Temperature Issue
Since this problem can replicate with internal loopback, can you please change the pin assignment as below and determine if there is channel dependency?
set_location_assignment PIN_AF25 -to "SFP_RXD0(n)"
set_location_assignment PIN_AG27 -to "SFP_TXD0(n)"
set_location_assignment PIN_AF26 -to SFP_RXD0
set_location_assignment PIN_AG28 -to SFP_TXD0
Besides, please refer to the attached screenshot, add the interface signals of native PHY to signal tap, and then compare the "tx_parallel_data" and "rx_parallel_data" to determine if there is a mismatch. The data drop may happen before this module.
- YYang795 years ago
We always test the data at these points. We usually call them xgmii interface. Only difference is a logical conversion of words from big endian to little endian between Native PYH parallel and xgmii. The data at xgmii shows OK.
I will add "tx_parallel_data" and "rx_parallel_data" into my signaltap to see if there is any difference.
