YYang79
5 years agoCyclone10GX Temperature Issue
I use a cyclone 10 gx fpga (10CX150YF780C5G) on my pcie card. One transceiver is used as a 10Gbps fiber link and other 4 transceivers are used as Gen1 Pcie X4 lanes. No external memory interfa...
SengKok_L_Intel
5 years agoBy right, both fPLL (core mode) can IOPLL can be used. However, the physical locations are different between both PLLs, so the routing difference may slightly impact the timing if the design is not optimized.
Usually, this is recommended to use IOPLL if this can generate the expected frequency for the core logic, and preserve the fPLL for high-speed transceiver usage.
YYang79
5 years agoThanks for having been going through this issue so long time with me!
Appreciated!
