YYang79
5 years agoCyclone10GX Temperature Issue
I use a cyclone 10 gx fpga (10CX150YF780C5G) on my pcie card. One transceiver is used as a 10Gbps fiber link and other 4 transceivers are used as Gen1 Pcie X4 lanes. No external memory interfa...
SengKok_L_Intel
5 years agoYes, it sounds good to use the LL MAC 10G MAC IP example design. If the PMA value is not optimal, you may see the high bit error rate when you vary the temperatures.
- YYang795 years ago
In LL MAC 10G MAC IP example design rev19.1 an IOPLL is used to generate 156.MHz and 312.5MHz, while in my design I use an fpll instead following the transceiver design guide line. That is the only difference. The example design works well on my board. So I changed my design to use IOPLL . The result is that it can work at high temperature now without error! It is 73C now but it used to fail at 57C.
It looks it is a big improvement at least.
My question is why is like that?
