Cyclone V SX SoC - DMA Controller Peripheral Request Interface
Hi guys,
I am trying to find out how the DMA peripheral request interface could be used. In the HPS component Interface description(cv_54028) and in the DMA Controller description(http://www.altera.com/literature/hb/cyclone-v/cv_54016.pdf) is no information how the fpga peripheral request interface must handled. my specific question is how is the burst length determined at fpga logic peripheral requests?? In the DMA Controller description is Peripheral Length Management and DMA controlled length management possible. I need Peripheral Length Management, but there are not the same signals like in the DMA Controller Interface description...:confused: I hope someone have experience with this. Thanks a lot for your Support ! (From HPS component Interface description) --- Quote Start --- peripheral signal interfaces The DMA controller interface allows soft IP in the FPGA fabric to communicate with the DMA controller in the HPS. You can configure up to eight separate interface channels. • f2h_dma_req0—FPGA DMA controller peripheral request interface 0 Each of the DMA peripheral request interface contains the following three signals: • f2h_dma_req—This signal is used to request burst transfer using the DMA • f2h_dma_single—This signal is used to request single word transfer using the DMA • f2h_dma_ack—This signal indicates the DMA acknowledgment upon requests from the FPGA For more information, refer to the DMA Controller chapter in the Cyclone V Device Handbook, Volume 3. --- Quote End ---16 Replies
In case anyone is getting stuck on CYCLONE V DMA peripheral request DMAWFP. (f2h_dma_req)
Here is the clue. First, search for per2modrst register in the Reset Manager on HPS altera homepage. Second, you need to make sure the DMA channels are taken out of reset, all 8 channels are being reset and remain reset after POR. For example, I need channel 0,1,2, you have to do this in the u-boot cmd: >mm.b 0xFFD05018 ffd05018: ff ? f8 ffd05019: 00 ? q > Finally your DMA330 should be able to respond to the requests from FPGA. good luck. - Altera_Forum
Dear ankpradh,
how does the user interact with your driver , so what is the high level application. I think in the dma driver there is the debugfs interface used,or in some other example driver . With this debugfs interface you can start an write or read to/from the FIFO via command line. So what happens if you trigger something from debugfs? 0.)debugfs function is called 1.)Register of fifo will be read (length information) 2.)The DMAC will be configured for this DMA Peripheral Request 3.) An "start" bit will be set in the "CSR" or named similar 4.) The fifo control logic sets the DMA Peripheral Request Interface signals (tx_single,tx_burst, rx_single,rx_burst) 5.) The dmac does the configured stuff .. So if you need two threads depends on which application you have? Again: What is the target of this project? - Altera_Forum
Oops you are correct, I had RX and TX backwards. The RX and TX are from the perspective of the DMA and not the FIFO, so TX is when you write data into the FIFO and RX is when you read data from it.
Dear fberndl
I am new to device drivers and I am having a tough time understanding the fpga-dma.c device driver. Can you please guide me on how to write the application program using this device driver? If anyone can share some sample code already written using this driver, it would be of great help. I have slightly modified the hardware this driver is intended for. Instead of the device being a loopback FIFO (data written to a FIFO and then read back from the same FIFO), I have created to separate FIFOs. Data is written into one, Passed to a second FIFO internally in hardware and then read back from that second FIFO. Can you please guide me on the changes required in this driver for that? Also I think that the application code should have 2 separate threads, one for writing and one for reading, else we wouldn’t be using the device to its full potential (i.e. the max data transfer speed achievable). Am I correct? Sincerely Ankit PS: As per your advice I have also replied to rocketboards mail thread concerning this driver. Haven't heard back though. I was hoping that you could help me. - Altera_Forum
Dear BadOmen
As per my understanding of the verilog code, I think that your explanation of the RX and TX interfaces is mixed up. It should be the other way round. Am I correct? --- Quote Start --- Those are the DMA "peripheral request interface" signals. The RX group is for flow control of receive channel of the FIFO (writing data to the FIFO) and the TX group is for the flow control of the transmit channel of the FIFO (reading data from the FIFO). --- Quote End --- I think the RX and TX here are in terms of the DMAC. It uses the TX channel to write data to the FIFO and RX channel to read the data from the FIFO. --- Quote Start --- tx_single represents the FIFO not full status rx_single represents the FIFO not empty status tx_burst represents the FIFO having a fill level equal to or exceeding the burst size rx_burst represents the FIFO having a fill level low enough that it can handle another burst of data written into it --- Quote End --- Again here the single and burst signals contradict each other. Only looking at the single signals, FIFO not being full implies that tx channel is used for writing into the FIFO and not empty implies that rx channel is used for reading from the FIFO. Sincerely Ankit - Altera_Forum
tx_single represents the FIFO not full status rx_single represents the FIFO not empty status tx_burst represents the FIFO having a fill level equal to or exceeding the burst size rx_burst represents the FIFO having a fill level low enough that it can handle another burst of data written into it rx_ack is a signal that pulses every time the DMA either issues a flush or acknowledges a peripheral transfer tx_ack .... same thing for the TX channel When I say "burst" in this context I'm talking about a predefined block of data and not memory-mapped bursts. The burst size programmed into the peripheral needs to match the burst size programmed into the DMA channel thread. These PRI interfaces let the peripherals communicate to the DMA letting it know when it's safe to transfer data. I recommend reading the DMA chapter of the technical reference manual as well as the comments in the custom FIFO IP to learn more about peripheral transfers and how the handshake works. This group of single, burst, and acknowledge signals is defined by Synopsys and used within the HPS block for all the Synopsys IP that communicates with the DMA-330 core. - Altera_Forum
Dear BadOmen
A question about the design: In the component editor of the Loopback FIFO (our flow control fifo), for tx_single/burst/ack and rx_single/burst/ack signals I see that although the signal types are export, the interfaces are tx_pri and rx_pri. How do I get this? What are these *pri interfaces? In my design there is a catch. I have to create a peripheral in which there are 2 fifos and some processing logic in between the 2. As per my understanding I will have to use fifos that have Avalon Slave MM write interface and Avalon Slave ST source interface for the input fifo and Avalon Slave ST sink interface and Avalon Slave MM read interface for the output fifo. I know that I can instantiate these fifos directly from the IP catalog, and when I generate the design, the verilog files will be automatically created. My question is that how do I add the wrapping flow control logic that you have used in the flow control fifo design example? Thank you for being so patient with me and helping me with this design project. I go to school and I lack the wisdom that you and all the other people have on this forum. Sincerely Ankit - Altera_Forum
I didn't realize the hardware was posted but I took a look and it contains the necessary verilog and .tcl file under /ip/flow_control_fifo. If you try to use that FIFO in your own design just move the IP directory to your own hardware project and the flow control FIFO will show up the next time you open Qsys. That design is just an old version of the golden hardware reference design with the FIFO added to the system and some wiring of the DMA flow control signals at the top level.
Dear BadOmen
I just came across this sample project on Rocketboards: SampleDmaQuartusProjectForFpgaDmaCInTheKernel313 This project uses the same flow control fifo. Is this what I was looking for? What is happening here? How can I recreate the steps of this project on my own? There doesn't seem to be any README file here. Sincerely Ankit - Altera_Forum
Dear BadOmen
Referring to your flow_control_fifo.v file. I am having trouble instantiating and integrating that component in Qsys. As per my understanding the data port and the tx+rx ports are connected to the DMAC; the csr port is connected to the hps. When I create a new component in Qsys, the data and csr ports from the verilog file are automatically detected as interfaces with correct signal types. However I am not sure what to do with tx and rx ports of the verilog file? Which interface would they be a part of and what would the signal type be? Should I make them conduit_end and export the signals? In that case how would I connect them to the DMAC at the SoCKit top level file. In short, would you have an example project with this fifo implemented as a peripheral? With regard to you reply above, again, can you please share some design project so that I can learn and modify it as per my needs. Sincerely Ankit
