12 years agoCyclone V SX SoC - DMA Controller Peripheral Request Interface
Hi guys, I am trying to find out how the DMA peripheral request interface could be used. In the HPS component Interface description(cv_54028) and in the DMA Controller description(http://www...
11 years agoI'm more on the hardware side of the fence so I recommend the mailing list at rocketboards as well.
One thing to know is that if you want to maximize the throughput of moving data from SDRAM in the HPS to the FPGA the fastest method is to have the FPGA pull the data out of the SDRAM directly using the FPGA-to-SDRAM ports. You can have a 256-bit wide direct interface into the SDRAM from the FPGA which will dwarf the throughput of having the HPS DMA pushing the data out of the HPS-to-FPGA bridge. A DMA capable of memory-mapped to streaming transfers is all you need to make this possible and it should be a lot easier to program for as well.
