12 years agoCyclone V SX SoC - DMA Controller Peripheral Request Interface
Hi guys, I am trying to find out how the DMA peripheral request interface could be used. In the HPS component Interface description(cv_54028) and in the DMA Controller description(http://www...
11 years agoI didn't realize the hardware was posted but I took a look and it contains the necessary verilog and .tcl file under /ip/flow_control_fifo. If you try to use that FIFO in your own design just move the IP directory to your own hardware project and the flow control FIFO will show up the next time you open Qsys. That design is just an old version of the golden hardware reference design with the FIFO added to the system and some wiring of the DMA flow control signals at the top level.
