12 years agoCyclone V SX SoC - DMA Controller Peripheral Request Interface
Hi guys, I am trying to find out how the DMA peripheral request interface could be used. In the HPS component Interface description(cv_54028) and in the DMA Controller description(http://www...
12 years agoActually I should have mentioned that the RTL I attached is infant what that FPGA DMA example driver is for. Peripherals can make two types of transfer requests bursts and singles. Burst requests are for transfer multiple words of data per request and single registers are for transferring only one word of data per request (by word I mean whatever data width the DMA is setup to transfer).
In the example FPGA DMA driver what should be happening is the DMA channel should be programmed with a burst length and the same burst size is programmed into the FIFO logic in the FPGA. This burst size can be changed but the important thing is that both the peripheral and DMA channel need to be using the same burst length. For example if the FIFO depth is 128 and the burst size for the peripheral is 4, that means when the DMA writes to the FIFO it's always being told there are at least 4 words worth of space in the FIFO. Now if the DMA was programmed for bursts of 8 words but the FIFO is programmed for bursts of 4, if the FIFO becomes already has 124 words of data buffered it will request a burst of 4 and the DMA will write 8 words and probably overflow the FIFO. Normally I recommend that if data is being moved between the HPS and FPGA that users put a soft DMA engine into the FPGA fabric. This makes variable length ST to MM transfers much easier because it's tricky to setup a DMA-330 channel when you don't know how much incoming data is arriving, that might not make sense until you read the DMA chapter and see what the channel microcode looks like. Also if a lot of data bandwidth is needed, using soft DMA engines in the FPGA also have the additional benefit of more memory HPS SDRAM bandwidth. The DMA accesses SDRAM through a 32-bit connection so at 400Mhz you are talking at most 12.8Gbps of bandwidth. The FPGA has a 256-bit aggregate connection to the SDRAM so running at only 100Mhz gives you 25.6Gbps of bandwidth from the FPGA into HPS SDRAM. If using a soft DMA sounds feasible to you I would check recommend using the modular SGDMA which is available in Qsys version 14.0. Unfortunately it doesn't have a driver so you can get a Nios II baremetal driver and documentation from here: http://www.alterawiki.com/wiki/modular_sgdma porting it over to run on the ARM is fairly trivial I'm told.
