12 years agoCyclone V SX SoC - DMA Controller Peripheral Request Interface
Hi guys, I am trying to find out how the DMA peripheral request interface could be used. In the HPS component Interface description(cv_54028) and in the DMA Controller description(http://www...
12 years agoThe burst length is basically an arbitrary number that both the DMA and the peripheral must agree upon. So it doesn't have anything to do with burst transactions at a bus level but rather an agreed upon number of transfers.
So when the peripheral requests a burst the DMA has to know what the burst size is ahead of time. Typically you make the burst size programmable in the peripheral and you pass this size to the peripheral and the DMA when setting up the DMA transfers. The reason why this is important is lets say the peripheral is a FIFO and the DMA writes into it. If the DMA and peipheral do not agree to the same burst length then the DMA could potentially read/write too much data causing an under/overflow to occur. I have attached a file that contains more details in the comments about how to drive these request signals and how to react to the acknowledge back from the DMA.
