15 years agocompare multiple std_logic_vectors
I have several FIFO's and i need to read out, the one with the most data first. I use the byte counter of the fifo to compare. But what is the best way to compare those vectors? if A > B and A > C and A > D then input <= A elsif B > A ...... You get the point* Or is there a better way ? For now i'm using above code but it is getting complex with allot of fifo's.11 Replies
--- Quote Start --- I would never recommend recursion in VHDL to a beginner. A recent example (http://alteraforum.com/forum/showthread.php?t=27911&highlight=recursion) showed someone trying to use recursion like they were writing software, and they caused a stack overflow in Quartus during synthesis. I agree it can be used when you know what's coming, but uncontrolled and misunderstood uses of it can lead to problems. --- Quote End --- You should give beginners some credit too, shouldn't you? I agree there are some pitfalls, but it is often very useful and elegant. Plus having a function makes it very little work adding (or deleting) inputs, (re-)writing the binary tree by hand can be tedious if you add or delete a member. --- Quote Start --- ..., then a binary tree would be the most effective way to achieve it --- Quote End --- That is exactly what the recursive function achieves. --- Quote Start --- A reasonable viewpoint. The suggested recursion is actually ending up in a binary tree. For a limited number of inputs (e.g. <= 8) the code text will be shorter when writing it enrolled. For a higer number of inputs, you possibly want a pipelined action, which unfortunately can't be provided by the recursive construct. --- Quote End --- Yes for a small number of inputs initially it may quicker to write the code flat-out (unrolled), but if you later have to add an input or two you end up retyping the lot. A for-loop will be easier to write but ends up in a stair-case logic, which is a lot slower. The idea in VHDL should be to look for re-usability. Together with generics, functions help a lot. You are quite right that a recursive function cannot be pipelined (which is a real pity). - Altera_Forum
--- Quote Start --- I would never recommend recursion in VHDL to a beginner. --- Quote End --- A reasonable viewpoint. The suggested recursion is actually ending up in a binary tree. For a limited number of inputs (e.g. <= 8) the code text will be shorter when writing it enrolled. For a higer number of inputs, you possibly want a pipelined action, which unfortunately can't be provided by the recursive construct. - Altera_Forum
--- Quote Start --- The idea is 'recursive programing'. This topic is usually covered in computer programming classes. Most of the time the teacher / professor will then continue to explain that you have to 'unroll' it using a for-loop construct to avoid stack-overflow and to minimize running-time, but in VHDL the compiler makes the nicest logic from it. Just take a look at the schematic in the RTL Viewer, then double up the number of entries, re-compile and look again at the RTL Viewer. You will appreciate what the 'recursive' action does. --- Quote End --- I would never recommend recursion in VHDL to a beginner. A recent example (http://alteraforum.com/forum/showthread.php?t=27911&highlight=recursion) showed someone trying to use recursion like they were writing software, and they caused a stack overflow in Quartus during synthesis. I agree it can be used when you know what's coming, but uncontrolled and misunderstood uses of it can lead to problems. - Altera_Forum
If you want exactly to compare n values (and not use an equivalent criterion for FIFO selection, as suggested by kaz), then a binary tree would be the most effective way to achieve it. I guess the FIFO depth and the number of FIFOs will be small numbers, both. So the effort is limited.
--- Quote Start --- But not what is happening inside the process. --- Quote End --- The idea is 'recursive programing'. This topic is usually covered in computer programming classes. Most of the time the teacher / professor will then continue to explain that you have to 'unroll' it using a for-loop construct to avoid stack-overflow and to minimize running-time, but in VHDL the compiler makes the nicest logic from it. Just take a look at the schematic in the RTL Viewer, then double up the number of entries, re-compile and look again at the RTL Viewer. You will appreciate what the 'recursive' action does. - Altera_Forum
Thx Josyb,
I understand what your code is doing. But not what is happening inside the process. (If u understand what i mean) I'll take the time to analyse it! - Altera_Forum
Another approach:
This scales easily to any number of fifo's, and will be faster than the if-then-elsif approach. You can use the MaximumIndex result to select the fifo to process. The MaximumValue tells you how many you can do for that fifo. I registered both the input and output of the module, just to find out how fast it will run, the function 'maximum' itself results in a fully combinatorial circuit.Library IEEE; use IEEE.Std_Logic_1164.all; use IEEE.numeric_std.all; entity idxmaximum is port ( Clk : in std_logic ; A : in std_logic_vector(7 downto 0) ; B : in std_logic_vector(7 downto 0) ; C : in std_logic_vector(7 downto 0) ; D : in std_logic_vector(7 downto 0) ; MaximumValue : out std_logic_vector(7 downto 0) ; MaximumIndex : out std_logic_vector(1 downto 0) ) ; end idxmaximum ; architecture a of idxmaximum is type idxval is record isvalue : natural ; idx : natural ; end record idxval ; type array_idxval is array (natural range <>) of idxval ; function subarray_idxval( src : array_idxval ; idx_from , idx_downto : natural ) return array_idxval is variable r : array_idxval ( idx_from - idx_downto downto 0) ; begin for i in 0 to idx_from - idx_downto loop r(i) := src(idx_downto + i) ; end loop ; return r ; end function subarray_idxval ; function maximum ( src : array_idxval ) return idxval is variable a , b : idxval ; begin if (src'length = 2) then a := src(0) ; b := src(1) ; elsif (src'length = 3) then a := src(0) ; b := maximum(subarray_idxval(src , 2 , 1) ); else a := maximum(subarray_idxval(src , src'length / 2 - 1 , 0)) ; b := maximum(subarray_idxval(src , src'length - 1 , src'length / 2)) ; end if ; if (a.isvalue < b.isvalue ) then return b ; else return a ; end if ; end function ; signal la , lb , lc , ld : std_logic_vector(7 downto 0) ; signal abcd : array_idxval(3 downto 0) ; signal maxresult : idxval ; begin abcd(0).isvalue <= to_integer( unsigned( la )) ; abcd(0).idx <= 0 ; abcd(1).isvalue <= to_integer( unsigned( lb )) ; abcd(1).idx <= 1 ; abcd(2).isvalue <= to_integer( unsigned( lc )) ; abcd(2).idx <= 2 ; abcd(3).isvalue <= to_integer( unsigned( ld )) ; abcd(3).idx <= 3 ; process( Clk ) begin if rising_edge( Clk ) then la <= A ; lb <= B ; lc <= C ; ld <= D ; maxresult <= maximum( abcd ) ; end if ; end process ; MaximumValue <= std_logic_vector( to_unsigned( maxresult.isvalue , 8 ) ) ; MaximumIndex <= std_logic_vector( to_unsigned( maxresult.idx , 2 ) ) ; end a ; - Altera_Forum
Thx i'll consider it. But also if there are two bytes in the fifo they need to be
send to the memory (if all other fifo's are empty) - Altera_Forum
consider setting a queue flag for each fifo; flag to be raised when it has a reached a given size then pass it to memory and lower flag followed by next fifo in the queue and so on.
--- Quote Start --- (I assume your work is video based from previous posts) --- Quote End --- True, But i need the images to be stored at the same time in one memory. Can't buffer a whole image in BlockRam, so i buffer in FIFO's first. Then i write the fifo with the most data into the memory untill that one is empty. Then i go one with the next one. Reading the fifo's at the same time (like u suggested) would imply parrallel writing to the memory what isn't possible in my case. (well it's possible to write 2 bytes at one time but it would be to the same adress)
