15 years agocompare multiple std_logic_vectors
Hi, I have several FIFO's and i need to read out, the one with the most data first. I use the byte counter of the fifo to compare. But what is the best way to compare those vectors? if A...
15 years ago --- Quote Start --- (I assume your work is video based from previous posts) --- Quote End --- True, But i need the images to be stored at the same time in one memory. Can't buffer a whole image in BlockRam, so i buffer in FIFO's first. Then i write the fifo with the most data into the memory untill that one is empty. Then i go one with the next one. Reading the fifo's at the same time (like u suggested) would imply parrallel writing to the memory what isn't possible in my case. (well it's possible to write 2 bytes at one time but it would be to the same adress)
