15 years agocompare multiple std_logic_vectors
Hi, I have several FIFO's and i need to read out, the one with the most data first. I use the byte counter of the fifo to compare. But what is the best way to compare those vectors? if A...
15 years agoThx i'll consider it. But also if there are two bytes in the fifo they need to be
send to the memory (if all other fifo's are empty)
