15 years agocompare multiple std_logic_vectors
Hi, I have several FIFO's and i need to read out, the one with the most data first. I use the byte counter of the fifo to compare. But what is the best way to compare those vectors? if A...
15 years agoAnother approach:
Library IEEE;
use IEEE.Std_Logic_1164.all;
use IEEE.numeric_std.all;
entity idxmaximum is
port (
Clk : in std_logic ;
A : in std_logic_vector(7 downto 0) ;
B : in std_logic_vector(7 downto 0) ;
C : in std_logic_vector(7 downto 0) ;
D : in std_logic_vector(7 downto 0) ;
MaximumValue : out std_logic_vector(7 downto 0) ;
MaximumIndex : out std_logic_vector(1 downto 0)
end idxmaximum ;
architecture a of idxmaximum is
type idxval is record
isvalue : natural ;
idx : natural ;
end record idxval ;
type array_idxval is array (natural range <>) of idxval ;
function subarray_idxval( src : array_idxval ; idx_from , idx_downto : natural )
return array_idxval
is
variable r : array_idxval ( idx_from - idx_downto downto 0) ;
begin
for i in 0 to idx_from - idx_downto loop
r(i) := src(idx_downto + i) ;
end loop ;
return r ;
end function subarray_idxval ;
function maximum ( src : array_idxval )
return idxval
is
variable a , b : idxval ;
begin
if (src'length = 2) then
a := src(0) ;
b := src(1) ;
elsif (src'length = 3) then
a := src(0) ;
b := maximum(subarray_idxval(src , 2 , 1) );
else
a := maximum(subarray_idxval(src , src'length / 2 - 1 , 0)) ;
b := maximum(subarray_idxval(src , src'length - 1 , src'length / 2)) ;
end if ;
if (a.isvalue < b.isvalue ) then
return b ;
else
return a ;
end if ;
end function ;
signal la , lb , lc , ld : std_logic_vector(7 downto 0) ;
signal abcd : array_idxval(3 downto 0) ;
signal maxresult : idxval ;
begin
abcd(0).isvalue <= to_integer( unsigned( la )) ;
abcd(0).idx <= 0 ;
abcd(1).isvalue <= to_integer( unsigned( lb )) ;
abcd(1).idx <= 1 ;
abcd(2).isvalue <= to_integer( unsigned( lc )) ;
abcd(2).idx <= 2 ;
abcd(3).isvalue <= to_integer( unsigned( ld )) ;
abcd(3).idx <= 3 ;
process( Clk )
begin
if rising_edge( Clk ) then
la <= A ;
lb <= B ;
lc <= C ;
ld <= D ;
maxresult <= maximum( abcd ) ;
end if ;
end process ;
MaximumValue <= std_logic_vector( to_unsigned( maxresult.isvalue , 8 ) ) ;
MaximumIndex <= std_logic_vector( to_unsigned( maxresult.idx , 2 ) ) ;
end a ;
This scales easily to any number of fifo's, and will be faster than the if-then-elsif approach. You can use the MaximumIndex result to select the fifo to process. The MaximumValue tells you how many you can do for that fifo. I registered both the input and output of the module, just to find out how fast it will run, the function 'maximum' itself results in a fully combinatorial circuit.
