15 years agocompare multiple std_logic_vectors
Hi, I have several FIFO's and i need to read out, the one with the most data first. I use the byte counter of the fifo to compare. But what is the best way to compare those vectors? if A...
15 years agoSounds excessive logic will be needed. I am not sure about the need to do that in your case (I assume your work is video based from previous posts). Consider waiting until all fifos have some minimum data size then read out all on same clock.
