17 years agoCIII / Configuration
I have a cyclone EP3C10F256C8 and configuration flash EPCS4SI8N. I have 2 of 10 boards which won't configure. All the signals are present: DCLK coming from the FPGA, CS, ASDI, and DATA coming out of the flash. In my reading I noticed that the flash drives out on the falling edge of DCLK and the FPGA latches also on the falling edge--is this correct? It seems more logical for the FPGA to latch on the rising edge if the flash is sending out on the falling edge. Otherwise it would seem that the tsu would be rather tight. The data line is point to point and is approximately 17mm in length. The clock line is point to point and is approximately 18mm in length. I believe I'm running into a timing problem but I can't figure out why 8 boards work great while 2 are behaving erratically. Any help would be greatly appreciated. Best regards, Rob
