18 years agoCIII / Configuration
Hi, I have a cyclone EP3C10F256C8 and configuration flash EPCS4SI8N. I have 2 of 10 boards which won't configure. All the signals are present: DCLK coming from the FPGA, CS, ASDI, and DATA co...
18 years ago --- Quote Start --- I have a cyclone EP3C10F256C8 and configuration flash EPCS4SI8N. --- Quote End --- Does the EP3C10F256C8 have an N postfix? i.e. is it a lead free part? The Flash you mention is a lead fre part Mixing Lead Free and Leaded parts needs careful control at assembly. I only say that because I have worked on a mixed board and seen signal integrity problems on some PCBs due to incorrect solder temperatures. From the Altera website: Q: Can I use both leaded and RoHS-compliant parts on the same board? A: Yes, both leaded and RoHS-compliant parts can be used on the same board. There are high-volume consumer products that are currently using both types of packages. However, using both lead and RoHS-compliant parts together will add to the complexity of the manufacturing process. Altera does not recommend this design for volume production. Might be worth checking with the PCB assembler.
