14 years agoCascading CPLDs on different PCBs
I'm designing a basic harness continuity checker based on shift registers implemented in Max V CPLDs. I'm aiming for a modular/extendable PCB design for the project as it has several benefits (cost, less complexity).
A uC communicates with my CPLDs using SPI. What I'm not sure about is how to best cascade these CPLDs in order to obtain a larger shift register. In a 144-pin TQFP, I only have 114 IO pins. Therefore, I can only implement a 114-bit Serial In Parallel Out or a Parallel In shift register. But by cascading these 114 IO devices I can obtain much larger shift registers. However, I'd like to place these additional CPLDs on a different PCB. This has the advantage that I can simply extend the device when I need. On smaller harnesses, a single 114 test-point PCB will suffice. On larger ones, I can cascade. At the moment, the CPLD is really just a shift-register. But in the future I'm hoping to implement a state-machine that can possibly implement more functions, like checksum to verify the contents sent by the uC etc. But that's for later and all I know is that I'd just use SPI for communication. As the CPLDs need SPI for communication, I am guessing that I need to pass these onto the cascading shift register i.e. each device will have a Serial Out (SO) pin. But it will also need to pass CLK, Chip Select and even a SI/MISO pin incase the uC needs to read back the shift register contents. I think buffering the signals would be good practice. But what would be the best way to actually connect the PCBs together? I suppose these really depends on the speed of operation. Fortunately, speed isn't an issue and therefore I'm operating at a very low frequency - just 62.5kHz. I'd like to be able to increase this, perhaps to 500kHz. I don't think I'll need any beyond that. At such frequencies, what's the best way to cascade PCBs and CPLDs? Please note, I'm aware that I can purchase a large 324-pin device. I'm afraid, I can't really use that as there is no way to inspect BGAs here locally. So I'm sticking with TQFP packages. I'm also aware that the topic, perhaps, mostly pertains to pcb-layout but I'm hoping I can get some CPLD/FPGA centric advice here regarding what signals I need to send as I'm not so sure about that. Would appreciate any responses.23 Replies
--- Quote Start --- I really like the Dip Switch + Internal Address idea. Just so I understand, I'm gonna re-iterate a few things: 1) Each board will have a 4-bit DIP Switch. The first 3-bits identify the board and the LSB identifies weather the CPLD is meant for driving the test vector or receiving it. --- Quote End --- In the case of the two CPLDs, there would only be a 3-bit DIP switch (which both CPLDs see), and the LSB of the address is determined by a CPLD-specific pin - 0 on the first device, 1 on the second. --- Quote Start --- 2) These 4 bits combined with an 12-bit internal address form a 16-bit address for a CPLD in the system. Just one thing that I still am confused about: is this 12-bit internal address the same for every cpld? --- Quote End --- The 4-MSBs of the address are determined by the DIP and hard-wired pin (0 or 1), and then remaining address bits are used to access the internals of the CPLD. If all the CPLDs contain the same design, then the 12-bits of address (or 20-bits, or whatever) would access the same design. Alternatively, your driver and receiver CPLDs could have different designs, but that same 12-bits would be accessing their internal memory maps. Personally I would just create an SPI-to-Avalon-MM master. The 4-bits would be decoded by the master to determine if it was the target, and then the remaining address and data bits would be determined by the rest of the SPI transaction. --- Quote Start --- I have a I2C temperature sensor and it has an address of 16-bits. However, the LSB of that address we can clear or set by tying a pin to GND or Vcc. This would sorta be the same, wouldn't it? --- Quote End --- Right, the DIP switch and hard-wired pin (0 or 1) perform this same task; they allow you to take the same 'component' but uniquely identify it. --- Quote Start --- I'm asking because I would prefer not to have to tweak a CPLD's 12-bit ID in the VHDL code every time I program a new one. I'd prefer if its a constant and the same for every CPLD. --- Quote End --- You would either use identical designs in all CPLDs, or two unique designs for the two CPLDs on a board. The DIP switch would then define the boards uniquely (3-bit DIP allows 8 unique boards, 4-bit DIP allows 16 unique boards, etc.). --- Quote Start --- but as the code may be different for the CPLD that's meant for driving the harness than receiving, I can make the 12-bit address such that the last 4 bit identify weather the CPLD is meant for driving the test vector or receiving it. --- Quote End --- That's the task of the hard-wired pin. --- Quote Start --- Essentially, the format is: BoardID - Internal Address - Driving/Receiving --- Quote End --- Not quite. The CPLD identified is also a high address bit. Lets take your example of a board with ID of 3, a 1-bit CPLD identifier, and a 12-bit internal address. The first CPLD (0) has addresses of the form 011-0-xxxx_xxxx_xxxx while the second CPLD (1) addresses are 011-1-xxxx_xxxx_xxxx i.e., the format is BoardID-CPLDID-InternalAddress The logic inside the CPLD, i.e., on the Avalon-MM bus inside the CPLD, sees the 12-bits of the LSBs, i.e., the xxxx_xxxx_xxxx bits. You can create an SOPC System/Qsys system that is unique to the driver and receiver boards. You would locate board identification registers at address 0 in both designs, and the uC would interrogate them to confirm the CPLDs are loaded correctly. --- Quote Start --- We, if we want, can even give the CPLD meant for driving a separate CS line than the ones meant for receiving. --- Quote End --- The two CPLDs are uniquely addressable. What they do it totally up to you. --- Quote Start --- 3) We can make a simple requirement for the system. All the boards connected to the system must have board IDs in a sequence i.e. if we have 3 boards then the IDs should be 0000b,0001b,0010b. The IDs cannot skip - if they do, we generate an error. We can even put a 3-bit DIP switch on the board with the uC and this switch could set the total number of boards connected to the system. So if this switch reads 4, but there are only three boards connected, it can generate an error. The uC will check this by pinging each board ID from 0000b to 0011b. If 0011b does not respond, we know there is an error. --- Quote End --- Now you're getting the hang of it. You'll end up with a system that abides by rules/conventions, and the micro checks that those rules are followed before allowing testing to progress. --- Quote Start --- Regarding the hardware... I'm thinking of going with LVDS Drivers. They look super-easy to implement and the I really like the fact I can run them off 3.3V. If what I've described is good and then I think I will send the following lines to go to the daughterboards: 1) SCK 2) MISO 3) MOSI 4) CS for Driving CPLDs 5) CS for Recieving CPLDs 6) Ground --- Quote End --- You only need one CS. The hard-wired CPLD ID determines which will respond. --- Quote Start --- Thank you for the link. I'll study it. I've been studying the ByteBlaster you uploaded for me. Thanks for that, it has been a great help. --- Quote End --- That particular design does not need to decode to multiple boards, but it'll give you a starting point. --- Quote Start --- You work in Radio Astronomy! Wow. I'm an amateur astrophotographer myself, in my spare time. :) --- Quote End --- We have some pretty clear skies here. You're welcome to visit! Cheers, Dave - Altera_Forum
Dave,
I really like the Dip Switch + Internal Address idea. Just so I understand, I'm gonna re-iterate a few things: 1) Each board will have a 4-bit DIP Switch. The first 3-bits identify the board and the LSB identifies weather the CPLD is meant for driving the test vector or receiving it. 2) These 4 bits combined with an 12-bit internal address form a 16-bit address for a CPLD in the system. Just one thing that I still am confused about: is this 12-bit internal address the same for every cpld? I have a I2C temperature sensor and it has an address of 16-bits. However, the LSB of that address we can clear or set by tying a pin to GND or Vcc. This would sorta be the same, wouldn't it? I'm asking because I would prefer not to have to tweak a CPLD's 12-bit ID in the VHDL code every time I program a new one. I'd prefer if its a constant and the same for every CPLD. but as the code may be different for the CPLD that's meant for driving the harness than receiving, I can make the 12-bit address such that the last 4 bit identify weather the CPLD is meant for driving the test vector or receiving it. We use the LSB in the DIP as board ID but ignore the MSB bit. If the least four significant bits in the internal address are F, then we say the CPLD is meant for driving the test vector. If they say 0, we say that the CPLD is for receiving the test vector. So here's an example of an 15-bit address (15-bit because we ignore the MSB of the DIP Switch) of a CPLD that's meant for driving a test vector located on a board with the ID '3'. 011-11101100-1111b For the CPLD on the same board but one meant for receiving the test vector, the address is: 011-11101100-0000b Essentially, the format is: BoardID - Internal Address - Driving/Receiving (the dashes are there to help see clearly) What do you think of this? We, if we want, can even give the CPLD meant for driving a separate CS line than the ones meant for receiving. This will eliminate all the need to differentie between the two when it comes to addresses. Yes, it would make it less flexible because we can't change via software what a CPLD is meant for (driving or receiving), but thats OK. Their role depends on the type of connecter they are connected to and so their role wasn't flexible to begin with. 3) We can make a simple requirement for the system. All the boards connected to the system must have board IDs in a sequence i.e. if we have 3 boards then the IDs should be 0000b,0001b,0010b. The IDs cannot skip - if they do, we generate an error. We can even put a 3-bit DIP switch on the board with the uC and this switch could set the total number of boards connected to the system. So if this switch reads 4, but there are only three boards connected, it can generate an error. The uC will check this by pinging each board ID from 0000b to 0011b. If 0011b does not respond, we know there is an error. Having the board IDs in sequence will make things slightly easier. The board count will also help identify if there is something missing or not. I think it would make things less ambiguous. I hope this system made some sense. I think it would be robust. Do you see any significant drawbacks? Regarding the hardware... I'm thinking of going with LVDS Drivers. They look super-easy to implement and the I really like the fact I can run them off 3.3V. If what I've described is good and then I think I will send the following lines to go to the daughterboards: 1) SCK 2) MISO 3) MOSI 4) CS for Driving CPLDs 5) CS for Recieving CPLDs 6) Ground But since I'll be using LVDS, that means I'll send signals 1 to 5 through them - which equals a total of 10 wires + 1 for ground. Thank you for the link. I'll study it. I've been studying the ByteBlaster you uploaded for me. Thanks for that, it has been a great help. PS: You work in Radio Astronomy! Wow. I'm an amateur astrophotographer myself, in my spare time. :) - Altera_Forum
One more comment:
The CPLDs have embedded User Flash Memory (UFM). You can use that memory to store a unique serial number for each board/device on a board. Your micro can check that each board at each device ID has a unique serial number. Cheers, Dave - Altera_Forum
--- Quote Start --- Ah, of course. So for a 4-bit switch, we'll have 16 board IDs already uniquely defined. 0000b through 1111b. So, suppose, there are 4 boards connected with the addresses: 0000b,0001b,0010b,0011b. As each board has a 74-bit shift register, we know the first board has test-locations 0 through 74, the second has 75 to 149 and on. All of this will be defined in the uC beforehand. --- Quote End --- Right. Depending on how you want your device addressed. The 'local' address map of each CPLD could have fixed length registers, eg. 16-bits wide, so you can have some identification registers at address 0, 1, 2, 3, and then shift registers following that. Or, you can have variable length registers at each address, eg. once you address the shift-register, you need to generate an SPI transaction that fills the whole thing. The AD9956 PLL is an example of a device with variable length shifts to different addresses. Read this doc for an example of the controller design: http://www.ovro.caltech.edu/~dwh/carma_board/ (http://www.ovro.caltech.edu/%7edwh/carma_board/) http://www.ovro.caltech.edu/~dwh/carma_board/ad9956_tests.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/ad9956_tests.pdf) --- Quote Start --- However, how would know uC know how many boards are connected? Or does it simply not matter? If there is no board with an address of 0100b, the uC receives no response. --- Quote End --- The test program should know how many boards are connected, and it can then go and check they exist. For example, the micro can go and read the CPLD image identification registers at address 0, 1, 2, 3, and make sure each responds with the correct info, eg., a version number, build timestamp, etc. --- Quote Start --- At startup, the uC can send a ping to all 16 addresses. So suppose it pings 0000b. If it receives no response, it knows there is no board connected there. It then pings 0001b, it the board pings back then the uC knows there is a board connected there. --- Quote End --- Right. It can do that and if it is expecting a board at address 0000b and does not find one, then it can report an error. At some point in the system design, you have to tell the software what to expect to find, and then generate a warning when there is an inconsistency with what it finds. --- Quote Start --- Yes, as I was reading this thread I felt I2C might work better as it already has addresses in the protocol. --- Quote End --- The key is to realize that you can define a protocol. It really just comes down to whether your uC's I2C controller can do what you want, or the SPI controller, or GPIO pins. --- Quote Start --- What I meant was, if each board will really ever contain 2 CPLDs (one for output and another for input) --- Quote End --- Why would you need one for output and one for input? The pins are bidirectional, so both should have the outputs read-back. I guess you are referring to one as your driver into the harness (with read-back), and one at the end of the harness for read-back. --- Quote Start --- can the board ID not be used as the CPLD ID? We really don't have any plans for cascading more than 6 boards - each board having two CPLDs (o/p and i/p each). --- Quote End --- Sure, but in this case, you could have a 4-bit board ID, with 3-bits set by the DIP, and the LSB set by a pin on the CPLD, i.e., the first CPLD on the board has an LSB of 0 and the other 1. Cheers, Dave - Altera_Forum
Dave,
A couple more questions: the 12-bit internal address for CPLD, will this be same for every CPLD? So, the 4-bit Board ID + 12-bit CPLD Address identify a unique CPLD in the system? I'm thinking of using LVDS drivers. I looked at some ICs and they look super easy to wire up! They use 3.3V and I have that on the system already. Regarding actual shift registers... the 240Z Max V I'm using is just $5. I think that's reasonable. I just think it's better to have an expandable system and the features I can put in like having a checksum and edge-sync. are very worthwhile as they put in robustness. One final question, should I have a separate "central" power supply? The boards could tap into the PSU for the required 1.8V and 3.3V. - Altera_Forum
--- Quote Start --- You have to know what you are physically connecting to, i.e., the wires in the test harness, so you have to define what the board IDs connected to what are. You could define the DIP switch setting of 0000b as the first board, 0001b as the second board etc. --- Quote End --- Ah, of course. So for a 4-bit switch, we'll have 16 board IDs already uniquely defined. 0000b through 1111b. So, suppose, there are 4 boards connected with the addresses: 0000b,0001b,0010b,0011b. As each board has a 74-bit shift register, we know the first board has test-locations 0 through 74, the second has 75 to 149 and on. All of this will be defined in the uC beforehand. However, how would know uC know how many boards are connected? Or does it simply not matter? If there is no board with an address of 0100b, the uC receives no response. OR At startup, the uC can send a ping to all 16 addresses. So suppose it pings 0000b. If it receives no response, it knows there is no board connected there. It then pings 0001b, it the board pings back then the uC knows there is a board connected there. I like this!! --- Quote Start --- Go and read about how I2C devices work. This is sort of the same scheme, except that there is a unique line for output versus input data. The separate lines allow for differential drivers, rather than a common driver. You could in fact use I2C to implement your system too (isolators exist, and I2C is deploying in buildings single-ended, so its fairly robust). --- Quote End --- Yes, as I was reading this thread I felt I2C might work better as it already has addresses in the protocol. --- Quote Start --- You'd need to define the SPI protocol so that your micro can address devices. You can define an address of 32-bits, but then you'd be wasting your time if you're only addressing a few hundred unique locations. So, you write the code with generics, but ultimately you need to synthesize with a fixed value. --- Quote End --- What I meant was, if each board will really ever contain 2 CPLDs (one for output and another for input), can the board ID not be used as the CPLD ID? We really don't have any plans for cascading more than 6 boards - each board having two CPLDs (o/p and i/p each). - Altera_Forum
Before you get too far along on the path of using CPLDs for each of your shift-registers, have you considered using actual shift-registers?
You could use a single CPLD to access multiple banks of shift-registers. Rather than cascading CPLD boards, you cascade the boards containing shift-registers. I like using CPLDs (since you can add features), but if you're worried about cost, perhaps using a CPLD to interface to shift-registers should be considered. Cheers, Dave - Altera_Forum
--- Quote Start --- Do you mean like this, except that CS would also be common for all CPLDs? --- Quote End --- Right - just like if you had the components all on the same board. As you see from your diagram, the difficulty is that you have to have a CS per device. JTAG gets around this by cascading all the devices in a daisy chain - so you can do the same thing if you like. I2C gets around this by having each device uniquely identified. Dallas 1-Wire devices get around this by having a 64-bit unique ID. So, you can leverage any of these methods - whichever happens to work for you. --- Quote Start --- If this is the case, then basically the uC will treat the CPLDs not as a giant shift register but really as multiple small ones. Let's assume I have 8 bit input vector 00001000. Let's further assume that my CPLDs can only implement 2 bit shift registers, so I need four of them. The output of the above test-vector is 10110001. The first CPLD is 10, second 11, third 00 and fourth 01. The uC will first address the 1st CPLD and read back it's contents. Then it will send the same instruction but instead of addressing the first one, it will address the 2nd one and so on. Is my understanding of this, at a high level, correct? If so, I quite like this. It's elegant, simple and robust. --- Quote End --- Yes, that is correct. Your test system is composed of uniquely addressable devices. --- Quote Start --- My only confusion now is regarding addresses of the CPLDs. You mention having a 4-bit DIP Switch that could be used as a board ID. How would know the uC know the value of each DIP Switch? --- Quote End --- You have to know what you are physically connecting to, i.e., the wires in the test harness, so you have to define what the board IDs connected to what are. You could define the DIP switch setting of 0000b as the first board, 0001b as the second board etc. In our systems, we have Dallas 1-Wire ID EEPROMs at physical locations. When you plug a generic module (FPGA+microcontroller) in, the location EEPROM contents are read, and that defines the module location address. In your case, when you plug the board in, you flip the DIP switches. --- Quote Start --- I could see it working if its located on the main board. If the switch reads 12, the uC knows the total number of boards is 12 and their addresses start from 1 to 12. Is this what you meant? --- Quote End --- No. Its an address for decoding. If there is no board with the DIP switch set to 0000b, then there will be no response to an SPI transaction with the device ID bits set to 0000b, i.e., all the CPLDs decode the ID and find that its not them. Go and read about how I2C devices work. This is sort of the same scheme, except that there is a unique line for output versus input data. The separate lines allow for differential drivers, rather than a common driver. You could in fact use I2C to implement your system too (isolators exist, and I2C is deploying in buildings single-ended, so its fairly robust). --- Quote Start --- Also, why the need for 12-bit internal address for each CPLD? Will this be hard-coded in? --- Quote End --- You'd need to define the SPI protocol so that your micro can address devices. You can define an address of 32-bits, but then you'd be wasting your time if you're only addressing a few hundred unique locations. So, you write the code with generics, but ultimately you need to synthesize with a fixed value. --- Quote Start --- Thank you very much for all the help you've given me. It would have taken me months to get through any of this stuff. Please know your help is immensely appreciated. --- Quote End --- You are more than welcome. Once you've figured out the approach you'd like to use, I'll review it for you. The nice thing about hardware languages is that it costs you nothing to build a system in simulation. Cheers, Dave - Altera_Forum
--- Quote Start --- You can treat your SPI bus as a common bus with MOSI going to all the devices in parallel, and MISO coming from all in parallel. This is where the device ID would be useful, as only the selected device would drive the common MISO bus. Alternatively, you do the JTAG trick where the shift-register passes through all the devices and then loops back to the master. That'll provide the read-back function. Cheers, Dave --- Quote End --- Do you mean like this, except that CS would also be common for all CPLDs? http://i.imgur.com/CaGEt.png If this is the case, then basically the uC will treat the CPLDs not as a giant shift register but really as multiple small ones. Let's assume I have 8 bit input vector 00001000. Let's further assume that my CPLDs can only implement 2 bit shift registers, so I need four of them. The output of the above test-vector is 10110001. The first CPLD is 10, second 11, third 00 and fourth 01. The uC will first address the 1st CPLD and read back it's contents. Then it will send the same instruction but instead of addressing the first one, it will address the 2nd one and so on. Is my understanding of this, at a high level, correct? If so, I quite like this. It's elegant, simple and robust. My only confusion now is regarding addresses of the CPLDs. You mention having a 4-bit DIP Switch that could be used as a board ID. How would know the uC know the value of each DIP Switch? I could see it working if its located on the main board. If the switch reads 12, the uC knows the total number of boards is 12 and their addresses start from 1 to 12. Is this what you meant? Also, why the need for 12-bit internal address for each CPLD? Will this be hard-coded in? Thank youvery much for all the help you've given me. It would have taken me months to get through any of this stuff. Please know your help is immensely appreciated. - Altera_Forum
--- Quote Start --- What I don't understand in your solution is that, if MOSI comes from the uC, how do the bits from the first CPLD spill over onto the next CPLD in the cascade? --- Quote End --- You can treat your SPI bus as a common bus with MOSI going to all the devices in parallel, and MISO coming from all in parallel. This is where the device ID would be useful, as only the selected device would drive the common MISO bus. Alternatively, you do the JTAG trick where the shift-register passes through all the devices and then loops back to the master. That'll provide the read-back function. Cheers, Dave
