14 years agoCascading CPLDs on different PCBs
I'm designing a basic harness continuity checker based on shift registers implemented in Max V CPLDs. I'm aiming for a modular/extendable PCB design for the project as it has several benefits (cost, ...
14 years agoBefore you get too far along on the path of using CPLDs for each of your shift-registers, have you considered using actual shift-registers?
You could use a single CPLD to access multiple banks of shift-registers. Rather than cascading CPLD boards, you cascade the boards containing shift-registers. I like using CPLDs (since you can add features), but if you're worried about cost, perhaps using a CPLD to interface to shift-registers should be considered. Cheers, Dave
