14 years agoCascading CPLDs on different PCBs
I'm designing a basic harness continuity checker based on shift registers implemented in Max V CPLDs. I'm aiming for a modular/extendable PCB design for the project as it has several benefits (cost, ...
14 years agoDave,
A couple more questions: the 12-bit internal address for CPLD, will this be same for every CPLD? So, the 4-bit Board ID + 12-bit CPLD Address identify a unique CPLD in the system? I'm thinking of using LVDS drivers. I looked at some ICs and they look super easy to wire up! They use 3.3V and I have that on the system already. Regarding actual shift registers... the 240Z Max V I'm using is just $5. I think that's reasonable. I just think it's better to have an expandable system and the features I can put in like having a checksum and edge-sync. are very worthwhile as they put in robustness. One final question, should I have a separate "central" power supply? The boards could tap into the PSU for the required 1.8V and 3.3V.
