14 years agoCascading CPLDs on different PCBs
I'm designing a basic harness continuity checker based on shift registers implemented in Max V CPLDs. I'm aiming for a modular/extendable PCB design for the project as it has several benefits (cost, ...
14 years agoOne more comment:
The CPLDs have embedded User Flash Memory (UFM). You can use that memory to store a unique serial number for each board/device on a board. Your micro can check that each board at each device ID has a unique serial number. Cheers, Dave
